Remote Start / Heated Seats Issues
Tom's LTZ
New Silverado LTZ owner here, love my truck but can't seem to get my heated seats working with remote start. I went to the vehicle settings and both heated and cooled seats are checked and here in Michigan its getting colder by the day. When I get in after its been started by remote start the seats are not warm. What am I doing wrong? Thanks in advance! Tom
  • Replies 219
This is an ongoing problem. Chevy will swear up and down they are working but they're not. You can't feel it when you get in. I ran my truck for two remote start cycles today (temp 34). Still nothing on the seats. Even when you push the heated seats button they're not that warm and heat unevenly, cold spots on the seat.
Try putting a towel over the seat while you cycle the remote starter. They aren't getting warm because there's nothing the seat hold the heat in. I know mine work but they barely warm until I sit down them..
Sent from my SCH-I535
I was under the impression my seats are not getting warm too with the remote start (I own a sierra) but I found out that they are getting slightly warm in the middle of the seat, I could feel the difference with my hand, the center was warmer than the edges.
Don't expect it to warm up the same as you use the heated seat button, it was designed to slightly warm up your seats, no more than that
I have the same problems, can't tell if the seat heaters or other features turn on. But what I really need is for the heaters and defrosters to turn on, an absolute necessity in upstate NY this time of year.
I don't get it, My wife's Nissan can do it. I assumed this truck could, had I known I would not have purchased it.
The guys that build these trucks live in Michigan, don't they get it?
Thanks.
On these trucks you have to make sure the seat heater is enabled in the settings menu.
To access the
personalization menu:
1. Select SETTINGS on the Home
page on the infotainment system
display.
2. Select Vehicle Settings.
Then find the section for:
Remote Start Auto Heat Seats
If equipped and turned on, this
feature will turn the heated seats on
when using remote start on
cold days.
Select Off or On. On some vehicles
select Off, On - Driver and
Passenger, or On - Driver.
Thanks to all for the information on the seats. Too bad GM has them like this, my Ford Explorer seats got nice and toasty after only about 10 mins when using the remote start. At least the heater gets the inside nice and warm!
I'm having this problem as well. In the Mylink vehicle setting I checked the box to enable remote start heated seats, and unchecked the box for cooled seats, just for good measure. We have temps in the 30's here in Houston all day today and not once has this feature worked. It's also worth noting that the heated seats themselves seem to do very little compared to other models.
The heated seats are on but it is a really low setting. Once you get in just turn the seat heaters on. Mine get warm within a minute or two even if it is below 0' F.. Also both the mirrors and rear window defroster work too. I have proven this on my truck multiple times living in Alaska..
My dealer told me gm is working on an update to how the seat heaters function. I have had my truck in several times and they still don't heat correctly. My passenger side back is toasty but the button is slightly warm. The driver side works pretty well on the days that it actually works. I am really upset over this but right now it's just a waiting game till gm fixes it.
I have a14' LT Z71 with cloth heated seats and remote start . My DIC does not give me the option in vehicle settings for remote start or heated seats.
Is this where you were looking?
page 5-44
Vehicle Personalization
Use the audio system controls to access the personalization menus for customizing vehicle features.
The following are all possible personalization features. Depending on the vehicle, some may not be available.
Turn the MENU knob to highlight a feature or option. Press the MENU knob to select the feature or option.
Press o BACK to return to the previous menu.
To access the personalization menu:
1. Select SETTINGS on the Home page on the infotainment system display.
Personalization Menus
The following list of menu items may be available:
. Climate and Air Quality
. Collision/Detection Systems
. Comfort and Convenience
. Lighting
. Power Door Locks
. Remote Lock, Unlock, Start
If equipped and turned on, this feature will turn the heated seats on when using remote start on cold days.
Select Off or On.
On some vehicles select Off, On - Driver and Passenger,
or On - Driver.
Good test this morning here in Michigan, it was 12 degrees out and I did the remote start for one cycle. Got in and the seat was not cold but not very warm. Hit the heated seat button and within about 5 mins my but was roasting. Just would like it to be toasty when you first get in but if thats the worse thing that happens for the truck I am not going to complain. It just turned 1200 miles and everytime I drive it I like it more and more.
I have 2014 Sierra Z71 1500. Having the sam issues with the seats not heating during remote start. I let the truck run through two cycles of 10 min remote starts and seat are not heating. Also, once I get in the truck and turn on the heat seats it take 10-15 minutes for them to heat up and the bottom is uneven. The back heats better. Took it to the dealer and they said its workingproperly - typical. I have seen several forums and blogs on this subject. It certainily is a common problem. Lots of disappointed 2014 owners me included. My friend has a new Dodge Ram and his works great with remote start, even the steering wheel heats up. I think GM has a design flaw that they are not admitting.
Planning to write GMC customer care. Be interesting to see what they say.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
