Remote Start / Heated Seats Issues
Tom's LTZ
  • Replies 219
Ok here we go again. (This should be made a sticky by now. lol) The seats in these new trucks are NOT like what you expect from previous years or other manufacturers. Thank GM for that. They do come on during remote start as long as it is turned on in your vehicle settings but, at a very very low heat setting. Think of it as a preheat. Once you get in and turn the key hit the heated seat button and they should get warm within a minute. However at that -30 temp it may take a little longer. Yes the seats do not stay on when the key is turned. You must hit the button and turn them on.
And as an added feature should you want your front windshield deiced while it warms up be sure and turn auto off as it wont defrost itself
Not sure if serious. But anyways I remember when I remote started my 08 gmc it would blow hot air on the defrost setting when it was cold and it would blow ac in the hot summer weather. Don't think my 14 does this, but really haven't used it long enough to determine either.
Sent from my iPhone 5 using Tapatalk
Unless you turn defrost on and auto climate off the windshield is ice covered and truck is lukewarm inside. Yes we know how to read the manual. But even my dodge is smart enough to defrost when cold temps in auto.
When I remote start and get in, if I've left the AC in auto, my front windshield is defrosted and it automatically turns on rear window/mirror defrosters as well.
at the minimum, the seats should be on the low heat setting when using remote start and its cold.
During the recent extreme cold weather, the seats were like sitting on an iceberg (even with (2) 10 minute
remote start cycles).
GM took a step backwards compared to my previous '08 when it comes to the remote start.
do these trucks have the mirror defrost? my mirror had lots of moisture on it from it being very humid out one night and I turned on the rear defrost and the back window cleared up but my drivers side mirror did not ever clear up it stayed with the moisture on it and I could not see out of the mirror the whole way home... my 12 had a separate button for the mirror defrost but I don't see one in my '14
The heated or cooled seats will not turn on during a remote start unless
they are enabled in the vehicle personalization menu.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
