Erratic Charging Sys 2007 Silverado Z71 4X4
Hi Everyone,
I have a 2007 Z71 4X4. I have been struggling with problematic charging System. The Voltage Gauge (Stock) and a Volt Meter (adapted to 12v accessory
plug) will at times read any where between 13.7-14.2 volts. The
problem is that both the Gauge and Meter will show that randomly the voltage
will drop to 12.2v, 11.8v it has even go down to 10.8v and held these for
a very long time to the point my battery has died. I have tested the alternator
both in the truck and on the bench, multiple times. It always comes back
good. I have done the same with the battery and as well it is good (after a
trickle charge overnight). I unplug the 2 prong control wire at the top of the
Alernator and it charges a constant 13.7v, problem is when I do this the
vehicles computer does not see that the wire is unplugged, in turn not
giving me a at Light or "Service Charging System Warning". It will
finally kick in after I drive (last time approx. 45min. then I stopped for
an hour, got back in, started the truck and after approx. 4-5 min, 2-3
Miles, the computer realizes its unplugged) then giving me
the "Service Charging System". I do understand that the
Computer will control the alternator and "basically turn it off when
recharge is not required" I guess where I'm confused is this normal for
the voltage Gauge and Meter to indicate anything lower than 12.6v (Since this
is the Batteries Voltage) if the A/c, running lights, and sometimes the
radio is on? Also shouldn't the computer pick up on the Alternator wire
being unplugged in a matter of a few miles not after 45min and 35miles?
Thanks for any feed back on where the problem is. By the way the dealer indicated that the wiring has a bulletin of a Milli-amp drop on the Battery
and Alternator Cables but mine checks out fine (They Say)
I appreciate any feedback
Jim
cant go wrong ever doin that but the dealer wouldve done that me thinks ,,,unless they just concentrated on the bulletin
jim,i havent looked it up but there are certain parameters that have to be met before a module will poop out a service **** message indicating a DTC in that system ,there is a thread here about alternators which i gave the decription and operation for the charging system,
let me know if ya want that ,,,rereading your post guys will tell ya to start with cleaning batt cables ,,,also ,it is weird that the system didnt see the low batt ,,,,,maybe getting it scanned too would be a place to start ,,,says the scooooobs lol
I'd clean all battery connections and body grounds, just for fun. Also check the condition of battery cables themselves, they have been known to go bad internally. has the battery been thoroughly load tested?
Also no need for multiple threads concerning your problem
    • We've been fans of the 40-20-40 front seat in the lower trims; specifically the leather option on the "3-across" version of the  40-20-40. I hope this can still be ordered in the "Silverado" or RST trim packages.  AND .... if dual exhausts are a part of the Custom trim,  does that mean a V8 package is available on Customs ?  Has the RST trim been discontinued ?  When ordering a V8 on one of these lower trims .... must it be the 5.7 ?  Or, on 4WD units can the 6.6 be ordered ?
    • I like it.   In a world of vehicle front ends that look like they've had a little too much nipping and tucking, I appreciate that GM went with a bold and professional look for the new Silverado and kept the aggression understated. The new 1500 looks a little more like the current 2500.   The interior looks well done as usual, although I'm not a fan of billboard screens on the dash. At least recess the gauge cluster screen. I see passenger screens as "keeping up with the Joneses'" in automotive interiors of late, which is fine. I don't think they belong in most pickups, but choice is good. Maybe some day I'll appreciate having one. Probably not, but, maybe.   Yet another steering wheel and airbag design. I wonder what it costs to have so many different models of airbags and buttons and steering wheel frames. IMO, pick a good one and stick with it. The new one is very...luxurious...looking. Again, not bad, but also not what I'd expect in a pickup.   GM has left us awaiting engine choice announcements and official details.     What will I be ordering on day one?   Nothing. I like my 2025 and it would be silly to get rid of it just to have a 2027.
    • I'm also waiting to see if they confirm Apple CarPlay, because I'm not interested in subscription fees just to use the hardware I already purchased.    In closeups it looks like it gets the Colorado/Canyon center screen based headlight controls which I despise. They also appear to lose all the hard switches for functions like seat heating and cooling, parking sensors, lane control, traction control, etc. which means they're all screen/menu based, so verdict is out on how well those will work with gloves or wet/dirty hands.  Admittedly they don't show the left knee area of the dash, but I don't see hard switches for locker control on the ZR2, and the "mode" switch appears to eliminate the rotary dial with a quick way to access tow/haul.  My 2021 has had multiple screen failures and at times the screen just locks up, goes black, or reboots while driving even after replacement, so loosing the ability to access many of these functions, especially lighting control would be pretty frustrating.   There aren't enough photos or detailed trim details other than one mention of "available microfiber trim" to confirm, but the use of microfiber on the seats and or center console is a deal killer for me.  Just because you drive a ZR2 or High Country, doesn't mean you don't work out of it, and that material is difficult at best to keep clean and looking decent.   Lexus and several other brands are using it on seats, dash, and door panels now, I assume as a cost and weight saving measure,  and it looks horrible 1-2 years into ownership.  I see what appears to be piano black on the doors and center console in some photos, which also has no place in ANY vehicle in my opinion because it mars and scratches too easily, especially for a truck.  Will be interesting to see what GMC comes out with when the Sierra is released as far as materials go.
    • Im a fan.  Simply moving the screen up helps the look of the interior.  I feel like GM dropped the ball on the current gen having the screen not at the same level as the top of the gauge cluster.  The GMCs look better with the vents above the screen to close that gap.
    • I hear you, its just not something one would even think of that the new oil in the container isn't filtered to a spec one would expect it to be.    As to a passenger vehicle theme and the maintenance requirement to meet to ensure a warranty is honored, these days with claims of life time transmission fluid on some models and the limited amount of oil changes that would bring one to the end of the factory warranty, that sells vehicles for those that like to hear "easy care maintenance free", but the manufacturer certainly knows different as to what that more than likely means for the longevity of some of the components if given that minimum spec maintenance. Then again I imagine there are a fair number of people that really don't care as long the vehicle gets them a certain number of years down the road because they are the type that want the next new thing, new and improved ... more bells and crap etc on the new one on the show room floor. Manufacturers have learned the phycological game to entice the customer out of their money !
