2014 GMC Sierra navigation system manual?
Trying to use my installed navigation system, all seems fine but the voice can only be turned down to 21 on the voice settings tab. Anyone have any idea how to get below that, she appears to be mad at me at that level. Also searched and searched for a manual with any description of the nav system and usage, did I miss a manual at pick up or what? Any help appreciated.
Within the nav menu you can shut the voice prompts off completely. I will verify the exact menu item that you need to hit in the morning.
I see where you can turn the prompts off and also where the volume adjustment is. I can make it louder but not quieter than 21 (I assume percent). With grandkids in the truck I like hearing the prompts, but with this quiet cab even at 80mph its pretty loud at 21. Figure there must be a minimum threshold setting somewhere, dealer item perhaps.
ok not a lot of interest in this topic, called customer assistance today, said to leave driver door open for 5 minutes with key removed to reset system, did so still only turns down to 21. asked if I got an infotainment manual and navigation manual no and no is there such a thing? Was supposed to get back with me as it is supposed to turn down to 0 anyone care to confirm they can turn voice prompts down to 0? awaiting a call back.
Hey there dkeven,
I'm sorry to hear your navigation is giving you trouble. I believe you mentioned you already did this but just in case you didn't, I referenced our Infotainment System Manual, and on page 50 it states, "Adjust the loudness of the audio feedback by pressing the − or + button. If a maneuver prompt is being played, and the main volume is adjusted, the prompt volume will update and be saved. As the volume of the voice guidance is being adjusted, a quick status bar displays, showing the volume setting." I'm sure your dealer would be glad to provide you with an Infotainment System Manual. If you don't receive a call back from infotainment or have any other questions feel free to PM us. Please also include your name, address, VIN, current mileage, and preferred dealership.
Jonathan A. (Assisting Jennifer)
GM Customer Care
yes that is what I have tried and while it will go louder+ once it get down to 21 thats it no quieter. cannot get it to lower beyond 21, will ask dealer about infotainment manual when I get there again but this does not fix the problem. now what
dkeven,
If you would like to pm me your VIN I would be happy to contact Infotainment to see if this is normal behavior or the possible solutions.
I look forward to hearing from you,
Jonathan A.
GM Customer Care
contacted infotainment "experts" gave the hold drivers door open for 5 min with key out than close and wait 5 min restart. If that doesnt fix it, either a. its not broke and only goes to 21 or B. its broke and you need to let the dealer look at it. so I guess they reallly dont know if A. it goes any lower than 21 or B. its broke. as none of my forum members have chimed in to tell me if they can turn prompt voice level down below 21 I am at a loss. so I guess B. when I get time I will waste it at the dealer seeing if they know if it gets quieter or just turn the prompts off and be happy with that. Seeing this is the first year for it in the truck I would guess a. they will not have a clue like the infotainment expert or B they will blow me off with that is the way it works. Infotainment expert did offer to get on line with dealer and relay complicated leave the door open for 5 minutes with key removed procedure and explain that a. its supposed to be that way or maybe b. its broke
you know the one question I have asked the forum and all the GM
infotainment/navigation experts has been, "Do the navigation voice
prompts turn down below 21?" So far three "expertly" trained reps at GM
infotainment dont know, Dealership service advisor doesn't know, and
aparently the forum isn't saying. Just saying if your an expert you
should have some expertise. While I applaud GM for having a separate
phone number and apparently group for infotainment issues, there are
other questions than, "why wont my iphone synch my music" types.
The voice prompt volume on my NAV turns down to zero with no issue.
Mike
My voice prompt only goes down to 24. It stops there but will go up. At 24 the volume is very low. 2014 ltz z71.
dealer checked out voice prompt today, mine and another one on the lot only turn down to 21 so guess thats it. Will have to figure she is mad at me when giving directions, good thing its a womens voice I am used to that tone.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
