Just FYI, it'll interfere with the front license plate.
Here's how I did mine:
Live in Oklahoma, so license plate wouldn't be an issue thankfully. I love your light bar set up, where/how you mounted your light bar by the grill? Is it a bracket that goes behind the grill or is it drilled into the bumper? I'd be happy with that setup too I think.
I didn't realize that about license plates.
So that's a 42 inch curved bar. The two mounts use bolts in holes I drilled directly into the grill which happens to line up with one of the thick "posts" on the inside of the grill. Easy improvised installation.
That's simple enough. I found a mount on N-Fab that I kind of liked and also seen the same N-Fab set up on this thread after doing some digging. .
50" curved and two pods per fog light
That's a 50" curved? [emoji15] I thought only a 40" curved would sit there
How did you secure it so low life's don't steal it
Its just bolted in through my front bumper cover in between the bumper and grille there and wired through like in between my headlight and grille kinda. The wire holds it pretty decent n so does the bolts but where i live thats not to big of worry..
n Yeah its a 50. it was supposed to go up above my windshield but didn't quite fit right with the brackets i had and so i was gonna send it back and we were messin around at the shop that night and held it up there as a joke, ended up looking just about right so mounted it and wired it in and it turned out pretty decent.
Plus now you won't have to deal with all that good glare! So win win
Pulled off the bumper tonight, removed the plastic trim piece to expose underlying metal, and test fit my new light bar. Fits perfect and looks pretty sweet IMO. Plan on doing permanent mount/wiring this weekend. Pics of bumper & test fit attached.
I'm a little late to the light bar game, but I'm looking to do this on my 14 Sierra 1500. How did you remove the plastic piece in front of the metal? Did you cut it out or is there a way to do it without cutting?
There are two bolts in each front fender skirts and 4 plastic tabs to push out from underside. If you scroll thru posts someone did a great write up.
Edited by Toddfather
Anybody put a light bar over the windshield yet? I don't know why but I've been wanting one ever since I put mine behind the grill.
member PDV127 has a curved 55" above his shield. Not many members have put one on, or at least I haven't seem many with one. I am on the fence about getting one eventually myself
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
