looking good. Any photo of the front with your Z71 grill . How much light got block by cross bars ?
A day later lol
Here you go
via Tapatalk on Galaxy Note 4
A day later lol
Here you go
looks good. Thank you for the photo. how much light would be loss with a double row ?????
Im not sure if thats measureable but regardless the light still shines thru. Only reason i didnt go double is because it will for sure cover up some of the bulbs/lights (w/e u call it) but the light still shines. Not sure if im making sense there .. ill grab a pic really quick of someone elses
Update:
Ok not my photo, this from the SS forum who helped me out deciding what to get. He had the RC curved dbl, switched to the single.
Here is his dbl row. You can that the top row is blocked. It will still shine but light will just go up n down rather than forward
Edited by quise2024
I went ahead and ordered up a brake controller panel and diced it up for my switches. Here's a few pics:
Where did you get the brake controller plate from and how much? Also,
how did you get the power for your switches to light up, like the words on the bottom part?
I chose to wire the bottom led off the parking lamp circuit. The top part comes on when the switch is rocked active.
Plate was off amazon. Find them all over the place right now on ebay, gm parts direct, rock auto had 2 in stock last week for 5 bucks more and :
https://www.amazon.com/ACDelco-23476237-Original-Equipment-Assembly/dp/B010GLVW90/ref=sr_1_1?s=automotive&ie=UTF8&qid=1486517945&sr=1-1&keywords=23476237
Ebay listings:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X23476237.TRS0&_nkw=23476237&_sacat=0
Ebay listings:
Thanks. I actually did some digging in the forum and found a previous part of this thread that listed a part number for just the plate, minus the factory brake controller switch. $14-16 depending where you buy. Here's a link to it with a price and picture https://www.tascaparts.com/oe-gm/22830877?origin=pla&gclid=Cj0KEQiA_eXEBRDP8fnIlJDXxsIBEiQAAGfyod40NB5-yy5_xqk7rDII1vX9DUu0DDS8Jp4EgpJYjisaAvlq8P8HAQ
There you go.
Can you guys recommend some underhood locations to mount 2 relays side by side? Pics would be appreciated as well.
SO the single row is the best way ? is that rough county light / brackets ???? Thanks
Yeah i also have the trailer brake so theres no room on that panel for me. I like how this setup is from someone on amazon though .. this is same switch i bought just with a white light
Do you have the amazon link?
So I don't have the light bar installed yet BUT I installed the switch that I wanted to use today LOL. Here are the pics below.
Keep in mind that my truck did not originally come with a center console, I installed it after buying the truck. I was able to get the USB ports to work. Prior to installing the center console, the truck had only one cigarette lighter so when I put the console in I left the second cigarette lighter alone with the intent of using it for a spot to install my aux switch. I had to remover the lighter and trim the switch a little but I think it turned out okay. The cover doesn't close completely but it's damn near close.
look good , need photos of light bar ??? Please
    250.6k
    Aries68
    Aries68
  • Who's Online   0 Members, 0 Anonymous, 361 Guests (See full list)
