looking good. Any photo of the front with your Z71 grill . How much light got block by cross bars ?
A day later lol
Here you go
via Tapatalk on Galaxy Note 4
A day later lol
Here you go
looks good. Thank you for the photo. how much light would be loss with a double row ?????
Im not sure if thats measureable but regardless the light still shines thru. Only reason i didnt go double is because it will for sure cover up some of the bulbs/lights (w/e u call it) but the light still shines. Not sure if im making sense there .. ill grab a pic really quick of someone elses
Update:
Ok not my photo, this from the SS forum who helped me out deciding what to get. He had the RC curved dbl, switched to the single.
Here is his dbl row. You can that the top row is blocked. It will still shine but light will just go up n down rather than forward
Edited by quise2024
I went ahead and ordered up a brake controller panel and diced it up for my switches. Here's a few pics:
Where did you get the brake controller plate from and how much? Also,
how did you get the power for your switches to light up, like the words on the bottom part?
I chose to wire the bottom led off the parking lamp circuit. The top part comes on when the switch is rocked active.
Plate was off amazon. Find them all over the place right now on ebay, gm parts direct, rock auto had 2 in stock last week for 5 bucks more and :
https://www.amazon.com/ACDelco-23476237-Original-Equipment-Assembly/dp/B010GLVW90/ref=sr_1_1?s=automotive&ie=UTF8&qid=1486517945&sr=1-1&keywords=23476237
Ebay listings:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X23476237.TRS0&_nkw=23476237&_sacat=0
Ebay listings:
Thanks. I actually did some digging in the forum and found a previous part of this thread that listed a part number for just the plate, minus the factory brake controller switch. $14-16 depending where you buy. Here's a link to it with a price and picture https://www.tascaparts.com/oe-gm/22830877?origin=pla&gclid=Cj0KEQiA_eXEBRDP8fnIlJDXxsIBEiQAAGfyod40NB5-yy5_xqk7rDII1vX9DUu0DDS8Jp4EgpJYjisaAvlq8P8HAQ
  • Like 3
There you go.
  • 1 month later...
Can you guys recommend some underhood locations to mount 2 relays side by side? Pics would be appreciated as well.
SO the single row is the best way ? is that rough county light / brackets ???? Thanks
Yeah i also have the trailer brake so theres no room on that panel for me. I like how this setup is from someone on amazon though .. this is same switch i bought just with a white light
Do you have the amazon link?
So I don't have the light bar installed yet BUT I installed the switch that I wanted to use today LOL. Here are the pics below.
Keep in mind that my truck did not originally come with a center console, I installed it after buying the truck. I was able to get the USB ports to work. Prior to installing the center console, the truck had only one cigarette lighter so when I put the console in I left the second cigarette lighter alone with the intent of using it for a spot to install my aux switch. I had to remover the lighter and trim the switch a little but I think it turned out okay. The cover doesn't close completely but it's damn near close.
look good , need photos of light bar ??? Please
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
