Dont do it. It is perfect the way it stands right now. The two inch drop shackle gives the truck a perfect stance. Leaves the back just 1 inch higher than the front. I have the same drop on my truck. I was going to take the blocks out too but loved the stance like it is. Here is a pick I took after the new exhaust.
Sent from my HTC One using Tapatalk
What brand of tires are you running? I am running 305/45/22 Yokohama. I took these tires and wheels off my 2010 and I will have to replace them probably next year and I am looking for something else.
Got my 3/5 DJM kit on today. Going to take the rear lifting shackles that came with the kit and put the stock shackles back on for a total of a 3/6 drop. I had used my 1/4" aluminum block in the rear with the flip so it sits up about 3/4" high right now. Without that block and the stock shackles it should sit perfect.
885A057F-5654-4FE9-9E2E-C92DAB493F3A_zps
Edited by brentadams646
I do, here is mine with the belltech rear 2" drop shackle kit on my 2014 All Terrain. Before and after....
before
after
what all did u have to get to level ur truck? just the shackles?
Good choice of wheels! I've seen many here in the forum, and those look great on your truck.
305/40/22
Thanks! I am debating on going back with 305/45/22 or switching to 305/40/22. i got a killer price on a Falken t305/40/22 yesterday . $140 ea.
I apologize if this has been covered somewhere already, I did search around and didn't find anything that specifically answered my question though. My question is, if I move the lower strut mount to the bottom of the spindle, like is done with the 2/4 drop, but I do not use the 1/4" spacer, how much drop will I get? I saw a post where a member put up a diagram showing that spacers create double the lift/drop that they are in thickness. So if I do not install the 1/4" spacer that is provided with a kit, will I get 1.5" of drop rather than 2"? Any help would be appreciated.
I installed the McGaughys 2" drop shackles and removed the 1.25" block already, and the rear of the truck now sits .5" lower in the back. My hope is that by relocating the bottom strut mount for the front suspension, I'll get the truck back to being 1" higher in the back for a tiny bit of rake, and less wheel well gap.
Thanks in advance, this forum is awesome!
Do it. Good price.
Anyone have a link to a set of shorter U bolts they purchased for rear block removal?
Edited by whodatfan
Do it. Good price.
GM part # 15002781 is what I plan on using when I do mine. That's the u bolt from a 2wd NBS when they used to come without blocks from the factory. Not cheep but I like to know the bolts holding my axle in are quality stuff
I have a issue and it couldn't have came at a worse time as I'm moving to Arizona On Monday and I have no idea what is going on. I had my 2" lowering shackle kit installed 2 weeks ago and since I've put about 250 miles on the truck with no issues and today out of no where something started knocking in the rear end area of the truck. Not all the time just every so often. But enough to get very annoying. I followed all the guidelines on the thread to install them (folding bed seems and such) I checked under the truck and everything is still nice and tight so I'm not sure what I should do.. I don't have any of the needed tools to take anything apart or install the stocks back on. I'm hoping is something dumb cause quite a few ppl have them installed and have no issues. It's a quad cab short bed truck. Thanks for any input it's down to the wire now and everyone's closed today
Just go by a 13/16" socket, ratchet and wrench and make sure everything is tight.
I had to remove my shackles I bought for my truck the shackles everyone is selling are for the 07-13 models even though they are listed for the 14's The shackles on the 14's are a tad bit wider, so when putting the older body shackles on, it allows for the shackles to rock back and forth making a popping noise when turning or backing up. I have a picture somewhere of my shackles but can't post it here at work.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
