I'm not sure there is a spindle yet for.your application but without knowing that. I'd start out a 2/4. 2" strut and flip kit with lift hanger
so mcghaughy's struts and a belltech flip kit? Is that what I need?
I'd get either full mcg or full belltech. Both are the same. Re mcg struts do ride a hair softer but they're both the same
so can I not get the 3" with just the struts? It says they do 1-3". Then I can just drop the back 5 and I would have my 3/5 drop.
This is where I get confused. They make drop spindles for 4wd but not with stamped UCA. What if I went with tubular UCA's? I dont mind spending the money but I am not quite sure what I need to spend the money on just yet. I know I what to have the proper suspension geometry when I finish and dont want to have problems I could have avoided if I would have installed the right stuff.
so if I buy aftermarket UCA's can I use the drop spindles so I can fix the camber that way?
Not sure if they'll fit. But I know Michigan .metal works makes camber correction upper arms they're like 3 or 400.
Just bought a 2017 Silverado double cab 2wd and plan on lowering it on stock 20" wheels and tires.
I have Mcgaughys 34270 adjustable kit on order and have a couple questions.
1- How low can I go on stock 275/55-20's? I'm thinking 3-5?
2- Would you use the McGaughy shocks that come with the kit or something else?
3- What is the easiest tool to cut off the bump stop bracket from the frame?
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
