Big Problem
TexZ71
3 weeks ago I had a oil pressure sensor error... Long story short I was 4 quarts low on oil. I brushed it off and placed blame on the dealership. Fast Forward three weeks and I'm driving to work with zero oil pressure on the gauge. I thought it was the gauge since I got no movement with the key in acc power. I decided to check the dipstick even tho I knew it was just filled less than a month ago... Low and behold the freaking oil is dry again and not even registering on the dipstick. I'm lost because I've checked for leaks and haven't found anything... PLS HELP.
2008 1500, 5.3L, crew, z71, 100,000mi, city/hwy driving
If it is going through that much oil you should be able to see it out the exhaust. Going by your miles on truck, and how many years old it is, 3 weeks is like 1200 miles. it should be pretty blue out the exhaust.
***Update*** put 2 quarts in and the oil pressure gauge is still at zero. I got a high voltage error code to the oil pressure sensor.
Where do you see "high voltage error"? What does the oil level look like now? If you have zero oil pressure, you would hear it on start up, within 10 to 15 seconds. First noise would be lifter noise. If you get that, shut the truck off. Although I would think that if you got the zero oil pressure while driving on the highway, there is already damage done.
I have an SL so no oil pressure gauge. I have the light on the dash that I think is more for oil level than pressure. I may be wrong, the light may be for pressure. Does your truck have the light as well as the gauge? If so, is that light on?
The engine threw the code to the diagnostics machine I have... Oil level still good.
No knocking.
Only has the gauge- no light.
Engine light was the only thing that came on when it had the code.
IM JUST GONNA START WITH THE OIL PRESSURE SENSOR, wires, and then the oil pump.
Update- I ended up removing the oil pressure switch and replacing it with a manual oil pressure gauge. I needed to know that the engine still had oil pressure because the dash gauge was on zero. So that eliminates the worst fear for me which was a internal issue or oil pump.
Next- testing the oil pressure switch with I jumper box and a test light.
Then if that checks out... Dash gauge, and wiring
You don't actually say you have oil pressure with the manual gauge installed, but you do infer it. Was oil pressure something over 10psi at idle?
Since you have the oil pressure sender removed, why not put a new one back in? I have no idea what they cost, but, if they are not real pricey I would replace it since it is out. I am old, and don't know how the newer systems are, but, in my day, oil pressure senders were basically a variable ground. In other words, you could short the wire to ground and you would get max oil pressure on the gauge. Two wire sensors required a resistor between the two wires to get the gauge to read something. Connecting the two wires together would give the opposite reading of the two wires not connected together. So, not connected may show 0psi, connected together would show max oil pressure. Some cars were the opposite, and open connection was max oil pressure, shorted together was 0psi.
the easy way is following this trouble chart ,,,,understanding how the computer controlled oil pressure gauge works,,,,i agree,replace the sender and try it
DTC P0521, P0522, or P0523
Diagnostic Instructions
DTC Descriptors DTC P0521
Engine Oil Pressure (EOP) Sensor Performance
DTC P0522
Engine Oil Pressure (EOP) Sensor Circuit Low Voltage.
DTC P0523
Engine Oil Pressure (EOP) Sensor Circuit High Voltage
Diagnostic Fault Information
Circuit
Short to Ground
High Resistance
Open
Short to Voltage
Signal Performance
Engine Oil Pressure 5 V Reference
P0522
P0522
P0523
P0521
Engine Oil Pressure Sensor Signal
P0522
P0522
P0523
P0521
Low Reference
P0523
P0521
1. Engine Oil Pressure Indicator Malfunction
Circuit/System Description
The engine oil pressure (EOP) sensor changes voltage based on the engine oil pressure.
The EOP sensor is a 3-wire sensor comprising of the signal circuit, the low reference
circuit and the 5 V reference circuit. The engine control module (ECM) supplies 5 V
to the EOP sensor via the 5 V reference circuit and provides ground via the EOP low
reference circuit. The ECM monitors the signal circuit of the EOP sensor to
determine the EOP sensor voltage is within the normal operating range of approximately
1–4 V. When the engine oil pressure is high, the EOP sensor voltage is high and the
ECM senses a high signal voltage. When the engine oil pressure is low, the EOP sensor
voltage is low and the ECM senses a low signal voltage. The ECM sends the EOP information
via the serial data circuit to the body control module (BCM). The BCM then sends the
EOP information
to the instrument panel cluster (IPC) via the serial data circuit.
Conditions for Running the DTC
The engine is running.
Conditions for Setting the DTC
P0521
  • The ECM detects that the difference between the predicted oil pressure and the actual
    oil pressure is either less than 47 kPa (6.8 psi) or greater than 50 kPa (7.3 psi).
  • The engine oil pressure is outside of a calculated working range determined by engine
    speed and temperature.
P0522
  • The ECM detects that the EOP sensor signal circuit is less than 0.1 V.
  • The above condition is present for greater than 10 seconds.
P0523
  • The ECM detects that the EOP sensor signal circuit is greater than 4.4 V.
Action Taken When the DTC Sets
  • The ECM records the operating conditions at the time the diagnostics test fails. The
    ECM displays this information in the Failure Records on the scan tool.
  • The IPC illuminates the EOP indicator.
Conditions for Clearing the DTC
  • The DTC becomes history when the conditions for setting the DTC are no longer present.
  • The history DTC clears after 40 malfunction-free warm-up cycles.
Diagnostic Aids
DTC P0521 can set if engine oil pressure is outside the calculated engine oil pressure
model stored in the engine control module. This can be an indication of mechanical
engine issues causing lower than expected engine oil pressure.
Reference Information
Schematic Reference
Instrument Cluster Schematics
Connector End View Reference
Component Connector End Views
Description and Operation
Instrument Cluster Description and Operation
Electrical Information Reference
Scan Tool Reference
Control Module References
for scan tool information
Circuit/System Verification
  1. Engine running, observe the scan tool Engine Oil Pressure Sensor parameter. The reading
    should be between 41–448 kPa (6–65 psi).
  2. Verify the engine oil pressure, refer to:
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the engine oil pressure (EOP) sensor.
  2. Ignition OFF, test for less than 1.0 Ω between the low reference circuit terminal
    listed below and ground:
    • Low Reference Terminal 3 (Gas)
    • Low Reference Terminal 1 (Diesel)
    • If greater than the specified range, test the low reference circuit for an open/high
      resistance. If the circuit tests normal, replace the K20 Engine Control Module.
  3. Ignition ON, test for 4.8–5.2 V between the 5 V reference circuit terminal listed
    below and ground:
    • 5 V Reference Terminal 2 (Gas)
    • 5 V Reference Terminal 3 (Diesel)
    • If less than the specified range, test the 5 V reference circuit for a short to ground
      or an open/high resistance. If the circuit tests normal, replace the K20 Engine Control
      Module.
    • If greater than the specified range, test the 5 V reference circuit for a short to
      voltage. If the circuit tests normal, replace the K20 Engine Control Module.
  4. Verify the scan tool Engine Oil Pressure Sensor parameter is less than 8 kPa (1.2 psi).
    • If greater than the specified range, test the signal circuit terminal listed below
      for a short to voltage or an open/high resistance. If the circuit tests normal, replace
    • Signal Terminal 1 (4.8L, 5.3L or 6.0L Gas)
    • Signal Terminal 2 (6.6L Diesel)
    • Signal Terminal 3 (4.3L Gas)
  5. Install a 3A fused jumper wire between the signal circuit terminal and the 5 V reference
    circuit terminal listed below. Verify the scan tool Engine Oil Pressure Sensor parameter
    is greater than 550 kPa (80 psi).
    • If less than the specified range, test the signal circuit for a short to ground or
      Module.
  6. If all circuits test normal, test or replace the EOP sensor.
Repair Instructions
Perform the
Diagnostic Repair Verification
after completing the repair.
  • 2 months later...
FYI- issue was the oil pressure switch
Turned off the AFM and that fixed the oil consumption problem
    • Good thing my wife doesn't frequent my automotive forums, she might get the idea of strapping me to a handtruck and leaving me curbside for the pickers day before garbage pickup!
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
