need help with wiper blades and headlights
i need some advice here,im a die hard GMC Customer,but the following make me hate my truck!!
i got an 2014 GMC sierra SL 4x4,i need winter wiperblades,i was told by my dealer that they dont do winter wiper blades for the 2014 yet...went to an aftermarket place,same story,the originals one get packed with snow,and they dont work good...
next thing...my headlight sucks!! on a flat road,on low beam,i can only see 150 feet in front of me...on highbeam,they are oki,not good,but oki...lets say,on highbeam, they throw the same distance as my sister chevy cobalt on low beam...the wrost is going down a hill on lowbeam,you can only see about 70 feet in front of you...verry dangerous
anny suggestions...i need help,as my dealer dont know what to do,they already did a headlight adjustement..
thanks,and im glad i foud this forum!!
  • Replies 38
I'm in for the update on the headlights, mine are weak, I'm thinking of getting some silverstars which I used to run in my older Fords.
I've got 0 problems with the headlights on mine, coming from a 2003 Cadillac with HID's and the stock lights on my 2014 truck are just as good if not better than the Caddy
OK, maybe this is a stupid question, but what are winter wiper blades. I know that there are winter replacements for the wire frame ones, but the 2014s have single piece rubber blades.
I live in MI and have no idea what you are talking about.
I'm guessing that the headlights only suck on the lower end models that do not have the Projector headlights?
here in northen canada, you need the winter wiper blades...they are fully covered with thick rubber,they dont clog with ice and they dont freeze...the problem with the 2014 sierra,its the new attachement on the wiper arm..different from the ones before...why would they change something that work good for something like that??
i heard that there is some GM Customer service peoples here...please help me,especialy with those dangerous headlight,i live in moose and deer country,and i cant see no shit,and believe me,im a truck driver that travel 200 000 miles with my semi plus my personal mileage,so i know how to drive at night.
going down a hill,its ****ing scarry!!
thanks!
i got the projectors,scottyboy...the dealership told me that they are all the same on the 2014 sierra...sl,sle,slt,etc...the only difference is that on a sl like mine,the bulb,produce the low and highbeam,and on the expensive model,the LED light bar on the bottom of the headlight produce the drl
I have the All Terrain SLT crew,and the lights are awful. Like I said the high beams won't make a stop sign light up,like they are aimed way down,dealer says they are where they are supposed to be. It is like they never took into account the rake of the truck.
You could probably aim them a tad higher for mor distance but I would assume you would loose some lower/closer light pattern. I know some retro fitted HID's on here. That would def help.
Sent from my XT1053 using Tapatalk
I had a LT with the reflector low and it was better then my SLT projector even after I put in the top Silverstar bulbs in mine. I'm thinking of changind out the projector with one shown in the thread below I'd just like to see some quantifiable data showing the improvement and a little better instructions before i start cutting up my headlights
http://www.gm-trucks.com/forums/topic/153789-first-retrofitted-bi-xenon-silverado/?hl=bi-xenon
Into live in Canada and had issues with my wiper's in the first snow storm.Dealer had no replacements so they bent them to put more pressure in middle, so far so good. My stock headlights work awesome.Silverado 1lt
I'll agree the stock wipers suck especially up here in Alaska. Has rain-x not released a blade yet?
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
