Halogen & LED Headlight Bulb Upgrades
Comscan, is there a specific reason that you used a separate harness & relay rather than just the "plug n play" with the oem wiring?
Just curious as it seems most just plug in & go.
  • Replies 832
Good question, I had previously installed HID's and led's both reputable plug and play kits but found neither were 100% reliable, problems ranged from one side not coming on through both going out until the next ignition cycle. Also this install made things much neater, there isn't the rats nest of connectors/cables canbus adaptors etc hanging out the back of the headlamps!
@Sierra Jon, got that BPS kit installed?
Yup! See pages 66/67! So far no issues.
Sent from my Nexus 6 using Tapatalk
Page or post? We are at post 785..that's a lot of scrolling. Repost please [emoji16]
It's page 66/67. There's multiple posts so I can't copy them all.
Bottom line is that the BPS perform light years better than the stock projectors (pun intended) but light dispersion is not as good as HID. The polarity needs to be reversed on the bulb side of the CANBUS. With some patience the harness and CANBUS all fit inside the housing behind the dust cover. And lastly, take the time to do trial and error on bulb orientation. It's close to 3 and 9 but if I remember correctly I kept adjusting slightly. Color says 6500k but it matches my 5500k LED fogs very well. It's been several months now though with excellent headlights, so I'm happy.
Ok, thanks my man. So, the real "issue" is light dispersion. Meaning, the LED lights don't project width wise or full coverage (dark spots) as well as HIDS's do?
Also good to hear that the 6500K you feel matches the DRL's and a 5500K look. Pictures?
The 2016 LED stock lights are fine. I would suggest that may be the direction you should consider. I had a 2014 and the lights sucked. The 2016 are good. Not super but good.
^^^ that'll cost me a lot more than upgrading to either LED or HID.
Did you price them? You may be surprised
Last I checked they were like 600 bucks...
Hard to tell in the pictures... It looks great in person. The front end in general just looks "current" without the halogen bulbs/color.
Do like the grille insert(s) have been considering that one myself?
I love them and they've held up very well. No fading etc...
That's good to know, how long have you had them on your vehicle?
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
