Halogen & LED Headlight Bulb Upgrades
Has anyone had any issues with running LED's in the Sierra headlight as they also operate as DRL's?
I'm not finding any info that shows there to be an issue but thought I'd ask.
  • Replies 832
I have an SLT with the dedicated LED DRL's. No issue there so far.
Sent from my Nexus 6 using Tapatalk
He has an SLE and the headlight is the DRL and they run at a lower voltage when being used as a DRL.
Do we know if on an SLE if the voltage is actually reduced for the DRL mode on the headlights?
With the stock bulbs it appears to me that the DRL's and low beam lights are the same brightness.
it has 2 modes. drl which is low wattage and full wattage. The highbeam is a seperate fuction and does not use the bulb. The highbeam is a solenoid in the projector that lifts the leveling plate.
Thanks for the information! I was aware of the highbeam operation but not of the drl operation.
So if I go with an LED headlight kit , such as from BPS Performance, anything to be concerned with if the LED bulbs operate at the lower wattage?
Depends entirely on the bulb. Mine worked fine in DRL mode before I added Gen5DIY harness however some bulbs may not.
My suggestion is only use a bulb that is made using Philips LumiLED chips/diode. They will cost more but you do not want cheap LED headlamps. Mine cost around $200 USD, I also changed the Projectors for another $150 which was well worth it. Only a few companies make actual LED's but there are a ton of company that make bulbs using these LEDs. I vote to stay away form anything using Cree after all you get what you pay for.
BPS Performance describes their kit as :
Our new G7 LED Bulbs uses the latest Philips Lumileds LUXEON ZES Chips
  • DC12-24V / 8000 Lumens/50W (4000 Lumens/25W per Bulbs) / Waterproof IP65 / Color 6500K
  • 100% Constructed of Aviation Aluminium 6063 for best overall heat control
  • Concept Heatsink to help stabilizing heat dissipation
  • 30000+ Hours Lifespan
Yup those would be good LED chips.
Ok so ..... drop in replacement headlight bulb?
Sent from my iPhone
BPS on amazon mentions needing a Canbus Module for the 9012 for the Sierra. Anyone know whether or not the Canbus is needed?
The Canbus module is only needed if you have a vehicle which uses the main headlight as your daytime running lights. (DRL) If you have LED DRLs then you don't need the Canbus.
This is not true. I needed the CANBUS or my lights would shut off when I started the truck. They would work fine in "ignition on" position but not while the truck was running. 2014 Sierra SLT.
I've got a 14' SLT as well and want to go the LED route. When ordering the BPS kit what all do I need?
Also, what fog's did you get to match? Thanks in advance! (links to purchase would be great too)
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
