Ok, with as cheap as this is and simple I am interested in it now.
With as cheap and simple as this is......GM should have made this standard. It's 2014 for crying out loud! Other Truck manufacturers are doing this. Why couldn't GM do it when they introduced this truck a year ago?
Finally got this done today. Very simple job and this write up made the wiring into the interior wire bundle very easy.
Thanks MotoMedic
Did mine the other day. Thanks MotoMedic, great write up, appreciate your time writing it up!
Is there a YouTube video for this?
The install? Probably not. You should be fine with just the posted instructions.. it's not a difficult install.
Thanks MotoMedic made install painless. Took less than an hour from start to finish.
thanks! im getting this! what do you connect the wires in the cab with ? scotchlocks?
Edited by 155
Up to you. Kit comes with taps/connectors but I prefer to splice in and used heat-shrinked connections.
I just tried to install mine...everything was fine until the wiring part I found the brown with yellows, I have 2, one smaller guage hten the others, then I found a couple solid greys all the same thickness...wtf anybody have anything different here..?
^ I believe one of the Grey wire is thicker than the other.. look at Moto's pic again to see the different..
    1981dustin
    1981dustin
  • Who's Online   1 Member, 0 Anonymous, 1,467 Guests (See full list)
