Just a bit of an update. I've gotten the front USB outlets to work as charging outlets but no communication yet.
That's what I was planning to do with them whenever I get around to find this mod. So far, I've only used my iPod and I like it in the lid part anyways... I'd only use the "new" usb to charge things
What did you have to do to get them powered?
Power and ground to the 6 pin connector and USB cable connected to the outlet and HMI control module. There must be some type of communication because I have always on power and ground to the USB outlet. Yet it goes to sleep about ten minutes after key off or opening door. and wakes up when the driver door is opened or key is on.The correct 6 pin connector is very expensive so I just used the terminals and shrink tube to keep from shorting. I would have to find the part numbers for the terminals. The cable I bought ( the only we could find in the GM part catalog ) plugs into the outlet but not into the module without some customizing. Had to shave the connector down with a razor blade.
#4 ground, #6 power. 1 photo shows back of 3 slot USB outlet (front). Other shows the very expensive connector you could use.
Forgot something. As for the terminals, I used terminals from GM. The part number is SAIT-A03GF-M064 . This is clearly not a normal GM number. You have to go to the dealer and ask the parts dept or service dept. They are usually considered a service part. Some dealers keep them in parts and some in service. There are about 30 tray full of terminals. These are in tray #27.
Ok I got the console in and swapped the harness from the original console into the new one, but I'm curious, how do I wire the inside console light( I get the power and ground for the light but how do I wire the switch that's down at the bottom of the console (a diagram of what color to what color would be really helpful) and I was thinking, couldn't I just get a USB splitter and split the main USB plug in (looks to b a mini USB or something like that and just run USB chords from that splitter to the front and to the inside of the console?)
so apparently you work for GM, ill abandon my search for that harness because obviously you put in a lot of effort lol
question though, the USB plugs you are trying to get working, would it not be easier to just get a identical plug setup as the one that is inside the center console with the 2 USB, input and SD card reader, get the proper plug and basically make the OEM harness split to support 2 identical plugs?
in theory, USB plugs can be split, we see it all the time on computers with a Y split adapter so you can plug in a mouse and keyboard and a USB key, or the keyboards you plug into 1 USB output and then it has 2 or 3 more USB plugs on the back of the keyboard for USB keys.
essentially that is what you would be making but for all the supported outlets in the one plug.
Just a thought.
great job with all the work to this point and documenting it, ill be following it once i decide to buy this console.
Edited by EaZ8
Just a thought.
The way I did the USB was the cheapest for me. Also the way the factory wires it. I had serious doubts it would work all along. I think I'm content to leave it as is now. 2 USB and an SD slot is more than I need anyway. Splitting is probably worth a try though. They are micro USB . I tried to find a micro USB male to male before ordering the GM cable and didn't have any luck. Standard USB cables may or may not plug into GM's priority connectors.You should try before investing it whatever cables, hub or "y's" you might try. At this point my front USB outlets will charge but I wonder if the 12v outlets will charge faster anyway. Don't know and probably will never use any of them anyway. As for the electrical connector, my cost was over $100.00 for that little bastard. For $10.00 maybe.
With or without extra outlets, I love my new console. Anyone on the hump thinking about adding it should do it. Especially like the 2 cup holder setup that actually holds a decent size cup.
Would do it again in a heartbeat.
Here is a wiring diagram for the console switch and light.
Edited by tbarn
Ok, so when I installed mine last night I just swapped the harness from the old console into my new one. I have the rear cig light plug in that I don't have connected, one of the two cig light plug ins at the front of the console I have plugged in but nothing else up there. What would b the best route; to cut the ends off of the new harness that came w the new console and plug everything else in and wire it to the old console harness? Could I get a diagram of how you did so for all the plugs? I'm really nervous about doing anything to this new console without a picture diagram or step by step. If really really appreciate it.
Thanks for all of your help.
I might do this myself but I am curious - how much air / space is under the console. I know there is a Bose subwoofer that fits under there if you have Bose in a console-equipped truck. I'm hoping there'd be enough space for car audio amplifiers or at least my processor.
Correct me if I'm wrong, GM's front USBs, from the factory, are only for charging - so I'm told by my salesmen whom I just called. I've never tested this. They will not send audio signal even if factory equipped. It's only the ones inside under the armrest that send audio signal.
Thanks
I went out on the lot and tried my USB drive on a new Silverado front USB slot. It works.
Schlegle1, did you leave the original harness in the new console? I left mine in and added the jump seat harness. I tapped into the original power outlet wiring coming out of the front of the ip.used power and ground to run the other power outlet and power to the wht/brn wire on the new harness to power the light. Ran a ground wire from circuit 1050 in the picture above to ground. I think it is a larger black wire. 15 amp fuse runs 2 outlets and light. it's an led so no real power draw to speak of. As I think back, I don't think the rear outlet works but I don't care. I'll never use the 3 I have now. As I said in an earlier post I would probably do it different if I did it over again. Was up against the clock so I didn't have the time to really think the process through. But everything works that I will ever need so it isn't worth changing.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
