looked into it and the online parts catalog showed the part #'s for a black console were back ordered or unavailable...
they only offered brown.. any one out there find anyone who has the parts available???
so anyone that ordered from gmpartsheadquarter pay a lot for shipping? First invoice said $75 for shipping, then they came back and tried to tack on another 100. Was this the case for anyone else?
When i ordered mine, the site stated it might charge extra for large items, I didn't get charged extra though. The console does ship in a huge box so I guess every dealer has their own criteria as what a "large item" is.
I thought $75 was high but I was ok with it. $175, no thank you
Anyone have the tan (dune) color jump seat and brown dash panel (like in post 881)?
If anyone has the Cocoa/Dune interior I can trade you for my center console.
I have the cocoa/dune jump seat in 2015 crew cab. Shoot me a pm and we can talk.
This might be a dumb question. If it is let me know. Will the armrest, latch and bracket of the jumpseat fit on the full center console I am purchasing to install. Trying to save a little money.
Anyone know why there are literlaly 200 Tahoe/Suburban center consoles on Ebay, but not 1 Siverado or Sierra??? How can that be? (Im aware the Tahoes and burbs don't fit the trucks)
Will a 2015 Gmc Sierra 1500 console fit in a 2015 Gmc Sierra 2500HD? I have a 23466980 and it doesn't show fitting in a 2500HD but shows it fits in a 1500. I was just wondering before I start to remove anything. Thanks
Squeezed it in.
Hey man great job! I have a 2014 Silverado 1500 same exact interior as you except my seats are a different color grey. Everything else like trim and stitching is the same. Do you by any chance know what all the part numbers are I would need in order to do this swap from a jump seat to the center console?
Thanks!
END !! all is working as it's suppose and all is connect to their fused location (installed missing wires, connectors, fuses and i like where is the arm for 4x4 located
also installed rears inners fenders oem liners........a lot less noisy on dirt road
Do you by any chance still have all the part numbers for everything I would need to convert the jumpseat to this? I see that they have changed numbers for the parts and I am not quite understanding where to find the correct trim (the grey that you have in this picture)
Many thanks to tbarn, savage and several others for great tips and pics to make this happen.
Just purchased the 5 main parts for my console install from gmpartsonline.net. Excellent customer service and she took pics of the console I was ordering to be sure it had white stitching. Prices are climbing fast and shipping was $160 or so. Expect to install next weekend.
Going to get a male to male (minis) USB and try to get one of the up front USBs to work for charging and music, and the other as tbarn and others have described for charging only. With a '15 Silverado the HMI USB in the upper glove box works for music and charging so rerouting it to the console USB should do the same, but I know many of you have tried without luck.
Question--do I have to disconnect the battery and has anyone had issues when disconnecting? Setting off airbags does not sound fun.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 238 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
