Well I am officially confused by all these part numbers. Is there any difference between the different year's consoles? Anyone have a 2018 black/white thread, with wireless charging part number? I have been told like 3 different part numbers and it's hard to verify which is correct.
Part number 84199886 is one that @Frank Jr recommended to me because it has the wireless charging lid that comes with it. Think this might be for a 2017 though, I have no way to verify.
Edited by FourThor
Not paying attention to the top wood trim part is this whar you are looking for. Black leather with white thread. this is part number
84199890 which is what I have has the wireless charging lid and is a few bucks cheaper than
84199886 I got my part number from gmpartdirect and I looked at rpo code options and cross referenced with this list from gmparetsgiant of complete consoles
https://www.gmpartsgiant.com/parts-list/2017-gmc-sierra-1500-2wd/console-floor-lower.html
according to what im seeing the only difference between the consoles is ck1,2,3(43) and ck1,2,3(53) - This might have to do with the double cab/crew cab thing. idk for sure.
Edited by zikronix
34 minutes ago, Scott Fish said:
I have a 2016 silverado extended cab,  reverse tartan trim.  vin is 1gcvkrec8gz357696
thank you for the help
what color are your seats. Ive see cocoa trucks with black consoles with reverse tartan. can you send me the a picture of the rpo codes in your glove box.
Scott Fish ,
Check this out :
2015+ Tahoe Center Console in 2014+ Silverado?
Look for this here , Something is at a angle the front of console
22884620-2015-gm-suburban-tahoe-sierra-1500-center-console-assy-new-oem-black-22884620-10.jpeg
2 minutes ago, frankinbus said:
Scott Fish ,
Check this out :
The SUV CONSOLES WILL NOT FIT THE TRUCKS.
Just now, frankinbus said:
Correct , If they go to this page and read these posts , They would know ,,
oh ok. every time i clicked it it kept just showing the picture to me...
this is the part most of these threads say to purchase.  there isn't the back trim or arm rest.
Johnny01: Thanks for the information.
Sent from my SM-G935V using Tapatalk
It's there I can vouch for it that's the part number I ordered. That diagram isn't showing it but it is there.
Sent from my Pixel 2 XL using Tapatalk
Johnn01: what year model and make do you own. And your saying everything is included with it.
2017 Sierra. I wanted the black console with white thread. My upper trim plate is Grand lace wood. I found my upper trim plate locally.
Here is my post from it. These are the parts I ordered for my truck. If you want a black console with white stitching then this is it. Remeber the top trim plate is not included in my parts list. If you put the parts in your cart at gmpartsnow and register an account they will send you a coupon code for 10% off after a few days. Shipping was cheap to arizona.
Another Successful swap. Ordered a complete console all parts new from gmpartsnow.com with a 10% off coupon.  I got the top console piece here locally. Everything combined shipped ended up being less than if I would have gotten it off ebay. I have the Axiom finish with grand lace wood trim.
Parts list if you need it.
84199890 - Complete console. Black with white stitiching w/ wireless charging.
23467516 - Sidetrim
22817347 - Sidetrim
22776807 - Front Bracket
11609982 - 2x Fender liner bolts
Specific to my truck
84024953 - Top Console with grand lace wood and axiom finish cup holders (Mine isnt adjustable, which will be changing once I figure out what part number I actually needed for that. EDIT: This option was removed in 2016)
19303285 - USB Cable
19119050 - USB Cable
For everything my total cost was roughly 600.00. 553.00 to Gmpartsnow shipped and 50.00 for the top piece.
Other console options Black with red thread 84131375
This one should be black with dark ash stiching (basically black with black thread) 84144697
There are a ton of other consoles, that are for trucks with bose, etc. I didnt get into filtering out rpocodes for those. Ultimatly the best bet is to go to the dealer fine a truck with the console you want capture the vin and RPO codes  if you dont need the bose version you can save some bucks. and send it to corbin at gmpartsnow or flloyd at gmpartsdirect.
Here is a link to my original post
Edited by zikronix
7 minutes ago, Scott Fish said:
well I ordered it today , we will see what I receive and what else I will need to order.
unless gm changed somewthing that parts list up there is all you will need for a console with wireless, black with white stitching. It comes with the lid even though it doesnt show it in the diagram. did you order 2 of the fender liner bolts. you need qty 2 there is only one in the bag. you can email who ever you ordered from and have them add it if you didnt. The usb cables should be correct since your getting a new console and you have the hmi but you can verify those on the first post of this thread. Also worth noting when you put in the driver side trim piece there is a plastic moulding on the support bracket below the dash. That has to come off.
Edited by zikronix
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
