Best place to get tires online?!?!?
Prokopchuk_9
Gonna need some new shoes again soon, the STT's are almost bald with only 35k Kms ahahah :)
I bought these on discounttiredirect.ca was a decent price but now I see the prices have went crazy on their website! Keep in mind I'm from Canada but willing to ship to border and drive across! Speak up fellow Canadians!!
Best place to buy some tires online?
Hello fellow Canadian
I tend to shop around and it certainly depends what you are looking for in the way of tires, my guess is you are looking for something more aggressive where I am closer to stock sizes.
I've picked up a couple of wheel and tire sets on Kijiji locally (sometimes you can find some great deals) then a couple more on Ebay (new take offs) and had them shipped to the border. If you do go Ebay check the sellers reputation as well when you find what you think is a good one seller see how he responds to complaints plus read the fine print, some of them are crooks.
A buddy of mine swears by discount tire as they have free shipping to Canada (but you need to pay the brokerage fees so its about one in the same). Discount seems to be the better deal by the time you get them back to Canada but are limited on selection and while Tire rack is cheaper when I was doing my research by the time you pay shipping + border fees then get them installed they are only a few more dollars at Costco and Costco gives you a decent warranty.
Now you have that 10% surcharge that is the Can - US exchange
Hope this helps.
I would call a shop at the border I bet their regular pricing would eat what you're going to pay up there if you don't tell them you're from canada you might get a deal shop around
Well turns out I'm heading to Minneapolis in a few weeks anyways.
I've searched high and low the selection for 35's is pretty limited. I want 35x13.5R20's too which is hard to find. Anybody know a good tire shop in Minnesota?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
