I like the badging on the dash. I want to do something there. Not that big but something like the SLT badging I pulled off the rear.
I want to put the texas edition on the glove box not sure if someone has pics or yay or nay??
Haven't seen any of those. I think Morris Lee put some All Terrain badges on the glove box and just a couple posts up, Nitrodatsik put some emblems on his
You can get the Texas edition badge from eBay or Amazon for like $20. Is probably going to be as big as the ones on the door but that's up to you.
look for the "texan edition" badge for the 2007.5-2013 Trucks.. My 2010 Sierra had the Texas edition badge in the upper glove box and it wasn't to big at all...
http://pages.ebay.com/link/?nav=item.view&alt=web&id=151464574663
Edited by thrasher2010
Yea thats the one im leaning towards I think it would be a nice fit
look for the "texan edition" badge for the 2007.5-2013 Trucks.. My 2010 Sierra had the Texas edition badge in the upper glove box and it wasn't to big at all... http://pages.ebay.com/link/?nav=item.view&alt=web&id=151464574663
I think the 14+ badges are bigger and would be a better fit
That turned out really good. [emoji106]
My Current Setup,2014 Silverado 2LT Z71,RCX 2.5 Level Kit,NittoTerra 33x12.50R20Lt's,Fuel - Octane D509 20x9 -12 Offset,All Chrome Plasti-Diped
My Up Coming Mod's,McGhauphy's 7"-9" Economy Lift Kit,Federal Couragia M/T's 35x12.50R20Lt's,OEM Tow Mirror's,Bushwaker OE Fender Flairs,Gtr Lighting Led Conversion Kit's 2,200 Lumen(High,Low,Fog),Black Spyder Venom Bull Bar,Iron Cross HD Step's.
Found the AVS vent visors that I had forgot that I had purchased. Put them on and they look ok only time will tell if they hold up.
Nuthin today...yet.
But it was a really early Christmas this afternoon when I checked the porch.
Nuthin today...yet.
Where did you get the Stahlbus oil drain?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
