I installed Access Vanish tanno, driver assist handle, z71 bed stickers and some black textured badges
Can you recommend a source for the blacked out badges?
The 6.2L badges came from emblempros.com. they were black but I resprayed them with textured paint. The z71 and SLT badges are the stock ones that came off the truck. I re-double sided taped them, scuffed them up and sprayed them as well with textured paint.
Tonneau Pro tri-fold cover
20% tint in the front and brow
Protexx spray in bed liner
20x9 Rockstar 2's Satin Black
275/60/20 Cooper Discover AT3's
Ready Lift 2.5" suspension kit
Aries 3D floor liners 1st & 2nd row
Under rail bed lights
Aftermarket brake control
Modified radio antennae (shorter)
Ventshades AeroSkin hood protector (smoke)
K&N air filter
Chrome exhaust tip with the Bow Tie
Plastidip/Glossifier front emblem
Removed rear Emblem.
I will post pics as soon as I get it cleaned up!!
That's a lot to do in a day^^^^^ haha jk post some pics of that beast
K&N air filter
Can't wait to see the pictures!
K&N air filter
Nice stuff. Where did you locate the after market trailer brake in the cab?
Do you have any photos? I like to add one and want to make sure it is in an area not in my way but easy to use.
Edited by PMattras
I put it below the dash above the gas pedal. i put in the part of the dash that there would be no visible holes. It is in an angle that some said wouldn't work, but it works fine. It's a old school one too, nothing fancy, i had it in my other truck. Ill get some pics up.
I wish it was all in a day lol it's between September and yesterday. It's raining or I'd go take some pics. It is going for a detail on Monday.
Ha I figured ... Good list of mods though
Thanks. Look forward to your photos.
bedumede.jpg plasti dip white to match my truck, looks real clean. I'm going to the the trim around the ac vents, doors.
Wicked Galaxy Note 3
^Did you do the rest of the trim or just the radio?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
