I'm not knocking the 6.2 I just personally don't feel the need for it or understand why you need it. Any time you are going to tow with your truck frequently as you say for the added power, you should have a diesel you get better fuel millage towing and have ample torque
The 6.2L is perfect for towing with a 1500 pickup. The added up side to it over a diesel is not having to deal with all the extra maintenance, and emissions garbage. The 2011 6.2L I had felt like it could pull a house, so I can't imagine how this new one is.
Finally got around to picking up my toolbox. Went with a Lo-Pro Husky from Home Depot. So far pretty impressed with it.
523F03DC-3B12-4CE8-B159-2A9E2D020232_6.j
BCCB4813-C27E-448F-A111-0E94DAFE58F6_3.j
4BB2FAFE-408E-4D7F-92DD-8960C9BAEE86_4.j
This is exactly what I have been wanting. Do you have a part number or anything?
Thanks, bud!
Get the low pro from Tractor Supply it's deeper and the lock dosnt break all the time. Had 3 of the Home Depot husky 1s key kept breaking so i sold the last 1 and just got a cover
I couldn't agree more about the Home Depot Husky tool boxes.. I had two of them, was about to take the 3rd one back but gave it my brother, when I trade my truck.. Now it's junky tool box.
Edited by thrasher2010
Windows tinted.
Any more pics or info on your truck? Looks like a leveling kit maybe? Nice color choice
Added a new grille and light bar today.
Sierra SLE???
Sent from my SG Note 4 on Tapatalk
leveling kit, and new Grabber AT2's in 275-70-18
Any rubbing with this set up? I've got a level and new wheels on the way and I'm looking into tires now.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
