I have the same thoughts about them "just stopping"...It appears Bushwacker has a trim piece, but I haven't been successful locating them.
3b46aaddb2284dbf2ae3b9cc33b63d8e.jpgsc
3dCarbon has some fender flares coming out that do a great job of following the factory body lines.
Sent from my SM-G900P using Tapatalk
Got backed into in the doctor's office parking lot!post-143298-145444173158_thumb.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
. Kerr what lift and tire set up you have on your all terrain?
2.5" Front level and 2.5" block in the rear. 20x10 Fuel Maverick currently wrapped in stock 275/55 Goodyear SRA
truck looks bada$$ - wonder if there's a way to get those RC flares to curve in and flush down to the bumper cap so it just doesn't square off in the very front...to me it looks like they did the right thing on the back flares but the front one just stops....? maybe it's my OCD showing through...!
you and me both bro. i didn't notice when i ordered and i didn't see it until it was installed ( i wish they were like the LUND elites) plus the color matching is a bit off.
if they don't grow on me i may just replace them.
side view is not that bad :)
i just waiting on the Amp Research XL boards to arrive now....it never ends.....
1C727632-C801-4223-81BD-CBDB2F344FBD_zps
DD760547-C5F3-450B-93B8-2934DAC834E4_zps
Edited by Sal9012
The fenders not matching would drive me crazy. I had a similar problem and sold mine.
yup, i used the shop paint option and big mistake, should have taken it to my guy. it bother the crap out of met, plus i am not happy with the front part wither, i may just buy the bullet and order the lund ones and get it done correctly this time. money down the drain...
Got 2 front window tinted and the strip for the front windshield.
Truck look sharp! Too bad you don't have a black toolbox now
Time to take it to the local line-x installer!
i do have a brand new black recess tool box that sitting the garage waiting for me to install this weekend.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
