Took off bull bar mounted led bar behind grille and installed new headlights. Had to order one bolt and nut for the tow hooks.adfc06bb154ad08d6c30f245f380269d.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
Edited by wildhunter
look better without bull bar . what size light bar ? more photo's head lights
Will take some tonite the lite bar was a 180w 28inch Cree spot beam I got about four months back off amazon think I paid 43 dollars for it I know it wasn not more than 50. Working on bed lights going to hook to a toggle switch.
Few night shots don't mine the wire under the rails installing a bed rug might have to add some lights if not the wires will be behind the mat.
61e6bfebc623c4ed9b05921e3f4dcd77.jpg971f875bae1e7a025bdc7da57d83d06a.jpg62abbeec9fbac4857e9af4338b53e9d1.jpg
looks good. bed lite switch - a rocker one would be more better ,wouldn't stick out ????
Do you have constant power to the bed lights? If so where did you tap into for power?
Didnt think of a rocker switch was thinking of something that would standout when i install the bed rug. May have to change it out. For power i ran a wire along the frame from the battey with a 5amp fuse it is hidden from eye sight.
Lifted. Zone 4.5"
Fuel coupler 20x9
Cooper discoverer stt pro 295/60r20.
Slight rub in reverse on the black plastic trim on the corner of the wheel well, but a little trimming fixed that.
1efb156b6013cae4d38d0381e82cb150.jpg4af0f3cb5bd1e71feb2f68f56bd0ff87.jpg0eebe933c5d3eb3229bcccf9e8e207dd.jpg419b0ec48b9f3eb6a00fba70170a7845.jpg8a2836085aecec8861aa026da835d719.jpge72028baaafa6ec958e45d637a8f9ec4.jpg
  • Like 9
Lifted. Zone 4.5"
Fuel coupler 20x9
looks good . need BIGGER garage ????
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
