I used Philips 921 LEDs for the backup lights
Same for your license plate?
Sent from my SG Note 4 on Tapatalk
License plate are # 194
where are you located?
installed a revolver X2 tonneau cover and put my wheels/tires up for sale on craigslist.
I just installed the new tow mirrors non powerfold on a lt silverado. I was wondering if anyone knows how to make the amber work as a clearance light and the reverse led work as both reverse and when I unlock at night for them to come on. If anyone has any ideas please let me know.
(The caption is a joke between some friends, nothing against girls who like tow mirrors)
Sent from my SM-G925V using Tapatalk
Several threads specifically for adding tow mirrors to these trucks. Depends on which stock mirrors you started with, DL8 or DL3. Do a search and you will find pages and pages and pages of great info that can answer literally any question you could possibly have.
For a 2014, you need the RZY jumper harness and a new door harness in each door.
The white LEDs are not designed as reverse lights or to come on with key fob like the puddle lights do on the smaller mirrors unless you were to do some complicated custom wiring job. From the factory they are wired as cargo lights, so you have to push the button in your truck and it will turn on the mirror LEDs and your other cargo lights in the back. That is how they are designed to work. If you push the button they work perfectly in reverse, and shut off when you put it in D. This is assuming you wire it with the OEM door harnesses like most do.
Amber lights will work perfectly as running lights if you use OEM door harnesses.
I am in Augusta, GA.
x2, I want those wheels!
I am down to ship them if the buyer pays shipping. don't know how much that would be though.
Ship them via grey hound. Probably cost around $50 to 100.
Sent from my SM-G900P using Tapatalk
Added LED's to the bumper step.
I have the same set up , control by cargo lite switch . looks good
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
