At last i almost had to call on my neighbor to download it he's 8 ?
Edited by JimmyJ_123
  • Like 5
I agree, does look a lot better!
I tried to look through your posts for the answer, but do you have the pace edwards switchblade tonneau cover?
Looks very good.... May have to get some spacers for my girls truck... Get them flush with the fenders would be ideal.
Sent from my Note 4 on Tapashit
The best spacers are going to be BORA. The BORA spacers are made from a solid chunk of aluminum. They also have sets made out of steel as well.
Sent from my SM-G900P using Tapatalk
Those are the hub centric spacers right?
Yes and on spacers 1.5" and smaller you have to trim the factory studs. Either 1.75" or 2" require zero trimming and are straight bolt on and go.
Edited by crafferty
. I have the roll n lock best investment for security. And no water intrusion. I went with Bora 1 1/2 no cutting of the studs. Edited by JimmyJ_123
  • Like 3
Got around to the tailgate today. Removed the lettering and plasti-dipped the emblem. Inversed the black/chrome from what I have on the front. I'm pretty pleased with the result.
I added some snow.... Good for i say 10hp
Tapatalk.... Wut r u doin.... Stapppp
Edited by Txjose
I just installed the new tow mirrors non powerfold on a lt silverado. I was wondering if anyone knows how to make the amber work as a clearance light and the reverse led work as both reverse and when I unlock at night for them to come on. If anyone has any ideas please let me know.
(The caption is a joke between some friends, nothing against girls who like tow mirrors)
Sent from my SM-G925V using Tapatalk
I added LED backup and license plate lights.
I have a 2015 Sierra Denali 5.3L. What type of bulbs did you use.
Sent from my SG Note 4 on Tapatalk
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
