Nope. It's come with chrome grill and chrome headlight bezel. But I'm gonna change them out once it gets here.
That's how I got my HC grill...a 2015 Black HC owner swapped out the chrome HC grill for a black color matched one. I know you can't wait to get her and start the mods. But this way, you'll get the HC interior that you like...can't wait to see and watch your fun!
30 inch light bar installed
Low beam
High beam
Low beam and fogs
Low beam and just the light bar
And that's the wireless button for the bar no drilling into the dash :) very stoked everything and this my truck leaving the shop 8cb2d01570fc5775313ad443a94cb809.jpg
Sent from my SM-G900W8 using Tapatalk
Added a B&W tow and stow with all 3 ball options. Literally just got it like 20min ago.... Delivered earlier via Amazon Prime [emoji1]
Here is the hitch..... Yes i have several browning rifles and a few buckmark 22s lol
Sent from my Note 4 on Tapashit
....the larger rear-end and 3.73 gears.
That's a good point regarding the rear end. You don't hear people mention it much only the increased engine power of the 6.2. Larger tougher rear end is definitely a plus. And with the 8 speed fuel economy is not far off from the 5.3 isn't it.
Low beam
High beam
Low beam and fogs
where you get that light bar? link? thanks
The physical size of both engines is exactly the same at 25.2" wide x 32.2" tall. What creates the larger displacement size is the bore. The bore of the L83 is 96.01mm where as the L86 is 103.25mm. Also, between the 5.3L crew cab/short box with max tow and 6.2L crew cab/short box with max tow the weight difference is 185lbs. For comparison the same configurations but with the standard bed (6'6") the weight difference is only 174lbs. I choose this configuration because both trucks will have the exact same drivetrain including the larger rear-end and 3.73 gears. In reality I have absolutely no clue what the difference in weight is between just the two engines but between the two trucks it's a very small difference of about 3%. Check out the two links below about each engine, it shows the materials used in the engine, horsepower & torque ratings, engine rpms and so on.
L83
L86
I just don't understand why you would get the 6.2 in the truck. Especially since the 5.3 can tow the same with 3.73 gears. It's not a race car since it's not aerodynamic nor is the gearing correct....to each his own I guess. I prefer the chance at better fuel millage
Sent from my SM-N920V using Tapatalk
Got my 8mm billet wheel spacers today. Drinking wine after the work week though so they'll have to wait for install!
Edited by TeeDub21
And what are you getting for mileage?! My 6.2 is averaging 18.5 back/forth to work. I've gotten 22 before on a 350 mile trip.
Fat fingered, and shot from the hip.
I get 15 on my 2 mile commute to work 13 towing and If I'm on Highway it's 25 ish depending on traffic and weather..... winter I get over 25 summer I get 23
4x4 with a 2.5" leveler, exhaust, 3.42 rear end
Simple: Power! ;)
  • Like 3
Got it from infinite off-road it's the 30 inch curved bar. With the wireless switch works great so bright I love it
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
