Installed some rigid dot fogs
Sent from my SAMSUNG-SM-G890A using Tapatalk
how do you like them? what beam pattern did you go with?
edit... just saw that theyre dot.
Edited by bigsam94
Hey brother.
How much modification to the opening did you have to do?
Sent from my SG Note 4 on Tapatalk
Hey brother.
The modification isn't all that difficult, just hard cutting your new truck. You have to cut the circular plastic bracket that holds the stock light housing. It can be done with a razor blade. Then you mark and drill holes for the new light brackets. The hardest part is getting all the hardware on and squeezing your hand in the bumper to tighten it all up.
Just put them in yesterday and didn't take them out last night for a drive . I can only imagine they will be great seeing all the light output in the daylight. The stock fogs couldn't light up my garage in the middle of a sunny FL day.
Thanks a lot brother. I'm assuming the rest was PNP correct?
Somewhat. You have to cutoff your factory fog light connector and splice in the connector for the rigid lights. Once you do that, it's all plug and play.
Installed some bushwacker fender flares and Nite-Lux LED bulbs :)
Edited by Jlm02a3094
Thought I'd share this. I know its the hot thing right now to black out everything. A lot of people are using plasti-dip. This is simple black vinyl usually used for making signage. I simply laid it over and trimmed to fit using a razor blade.
Sent from my Nexus 5 using Tapatalk
looks good. black out that truck ?
No, I'll be leaving some chrome. Just not as much as there is now :)
Josh
Not exactly. Cut off factory plug to splice or solder in the rigid connector.
Just drove it tonight and way worth it!
Had the truck Diamond coated and rust proofed today.
Edited by SkippyG4
  • Like 4
Had the truck Diamon coated and rust proofed today.
what's Diamon coating ???? looks good for a red truck
Rust proof; where and using what method. Thanks in advance
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
