Got my rear Ranchos replaced under warranty with only 16k miles on them. Never towed a trailer heavier than 2200lbs and had no more than 200lbs in the bed.. Pretty shitty..
Nope, I already had the factory lights in so I just spliced into the factory wiring harness in the bed and wrapped everything back up. There aren't any extra pins on that connector, are there?
Sent from my SM-G920V using Tapatalk
no, I don't think so, you could just solder in at the connector, but I think your way achieves the exact same result
Removed GMC emblem on tailgate the other day and installed white reverse and cargo lights today! Thanks Tallspawn!
Sent from my Nexus 6P using Tapatalk
Sure thing!! I'm still loving mine!!
Sent From My Galaxy S6 Edge+
Oh yea, also replaced factory antenna with this stubby. No idea if it even works. Just listen to Spotify mostly.
I've been considering this, can you post a pic further away?
Sure! I'll grab one tonight if it doesn't turn out I'll take one in the morning.
Best I could get at night in a garage. I edited them a tad to hopefully make it easier to see the antenna. It's pretty small.
I will add that besides how much better it looks, it is nice not hearing it bang against the garage at work or my garage at home.
Edited by cjz28
Cool! Thank you for posting, I have the same issue at work, it's annoying lol. I'll probably grab one, thanks again!!
Dropped off for some Audio Surgery.....
Replaced my stock LTZ fogs with diode dynamics XML2 bulbs should be done with the matching HID low beams by tonight. Thanks fast headlights for the fast shipping!
VneTkDZ.jpg?1
0rukAZ6.jpg?1
Where to get vinyl from? #nOObquestion
Sent from my iPhone
Got mine off eBay, have had it on the truck for 2 months and still looks amazing and holding strong
I am curious where / how you spliced into them. (Any pics) I optioned the LED bed lights on my build and want an extra set up front for when I get my Fold-A-Cover on next week. I grabbed an extra set on ebay yesterday. And really want to do this since my dealer told me they couldn't do it, since it isn't a Chevy authorized option.
OEM rear wheel well liners. It looks so much nicer.
Have pics of these? How far down do they cover?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
