A lot does but not all. I noticed it the most with pollen here in New Engand. Blows off with the wind. I try to mist with detail spray and wipe down with microfiber cloth right after washing. Bugs hose off way easier too.
Yeah I'm also curious as to where you had your truck detailed
I just got quoted $930 to get mine done is that good or bad?
holy crap! I've never had my truck detailed... that is a crazy price to pay.... what all does the detail involve for all that money??
2015 1500 LT Silverado Midnight Edition
Opti-Coat Pro I'm guessing it's a clear coat over your paint.
A normal wash and wax is $80 I'm debating if I should just get my doors, box and flares clear vinyl wrapped for that much money.
I don't want trees to scratch my paint if I can prevent it for a couple hundred bucks I will, but I don't like sinking too much money into something that only loose value
Edited by SuperSierra
Lol. Detailing correctly isn't cheap. It's that "you get what you pay for". Paint correction takes lots of time and skill to be completed correctly. The paint has to be corrected before any clear bra is applied too, or the scratches underneath will be visible.
You can always find "that guy" that'll detail it cheap, but keep that in mind. Cheap. Anybody can throw a coat of wax on and mask swirls and holograms.
I paid $600
I paid $600
So this guy is taking me out to the cleaners and not in a good way.
How long does Opti-Coat Pro last?
Hey im from CT too! who did your detail? im from central ct and i cant find anyone trustworthy
http://www.proandlocal.com
I was told it'll last 2-3 years. I plan on having it redone every spring after the harsh winters.
No shop will have the same prices. Ask and see his whole process.
I'm going to take a swing at doing it myself. It's under 100 bucks to order the large kit. If you screw up it says you can remove it with alcohol and wax.
It's around $500 here. Debated on trying it myself but the guy said it's about an 8-10 hr job...no can do. That was with a one step polish/sealant.
I was just watching this. So it seems the key is too make sure it's 100% clean so that would take a while. But applying it doesn't seem to be very stressful
That's just for the ceramic sealant. It's just like painting, it's all in the prep work. The paint has to be completely stripped, clayed and polished first before a sealant is applied.
Clay bar with proper lubrication would take ~30 minutes if you do this annually...and don't have rail dust on your vehicle or anything ridiculous...
Spot on.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
