Installed under hood lighting! LED kit from diode dynamic, pin switch for auto on and off. Will get better pics tonight ;)
I had already added LED lighting under the hood to my mod list, but now I get to add the on/off switch too. Where did you get yours? How much? Does the hood "bounce" (when you close it) screw the switch, rail, or hood up any? Was the switch a bit of a pain to dial-in/rig?
I'll get you some close up pics later of the switch and reply with more info :)
Stone blue with red detail, superman themed sorta 5aa5ec2fc5a4398e21caf22c8bb42404.png
Thanks!!! My wife and kids saw this, as I was looking at the recent updates, and want me to do the Superman on my Silverado. So much for trying to "midnight edition" mod mine.
Lol, sorry.
Kids and parents come up to my jeep with a batman theme all the time asking if they can get a picture.
You could do the superman in flat black and try to make it not stand out so much if you want to do a black on black theme.
Traveling to my grandparents today for the holiday & spotted this at the dealership. Wish I had one, so wicked.
Will that hood fit on a '17 1500 silverado without changing any other parts?
This should read: "almost cheated on my current K2 today"
Nope. Have to change the whole front end, from what I've read. There's a post on here somewhere from someone who did it.
I thought that was someone that did a 14/15 to 16/17 swap? The hood looks like it has the same lines as the current 16/17 1500 hood.
Recently had her detailed at a local shop. Full paint correction and Opticoat ceramic sealer. Look at that reflection on the door!! Damn! Also dropped the Diablo Tune and added a Black Bear Tune. There is a noticeable difference.
  • Like 4
Nice!! Mine is having all that done in a couple weeks! Local shop is booked till then but getting full detail in and out with headlight restoration! Not happy I have to wait but it will be worth it!
Ok so, I am going to say hell yes this will do well for working in the dark! Here are some night pics, no flash.
Night shot of lights
Night shot of engine bay
The kit I got was this one from Diode Dynamics, Cool White.
No bouncing, pin switch is just above the fender top when hood is open and compresses easily on close. Simple install, I used an existing hole in the fender near battery. Few tries to get it to the close position I wanted.
Install for lights was easy, I uses some wire base mounts to zip tie to, and will run the wires under the insulation and mount more bases in there, have to go get some (along with christmas trees I lost ha)
Also need to cover the wires and mount them better by the hinge, but I got tired today.
Hope this helps!
  • Like 5
Finally washed it during the weekend and took it for a spin today(not my daily driver) for July 4th... my son always tries to get me to drive it everywhere we go, :D
Didn't realize my wife was peaking when I took the picture.. haha
Edited by jpinoy
What shop do you use?
Time for some tow mirrors?
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
