Look's Good - HOW do you like your running broads .
Thanks! I love my running boards. They’ve held up very well with the hell they go through on the road. Lots of construction around where I live so there’s sand, rocks, and concrete everywhere that pepper them daily.
I do hope your truck works out, but I was on the phone with Shane long before I seen this here. I seen the video first with Troy, take a look at his video about your truck, you'll see my reply. Unfortunately, my truck is worse than yours. I know it's no contest I would want to win, but, they will need to strip the entire truck from bumper to bumper, roof to running boards, before they can do anything else. All the while, hoping my clear coat doesn't get burnt through, yet again. It's going to be a very expensive endeavour. It's been mouths of dropping off my truck, driving some pos rental for days on end. If I end up taking my truck to Shane and Troy, they could make more videos on what NOT to do, and what it will take to fix it.
Here's a quick pic, the entire truck looks like this...
that is pretty bad. My truck was probably just as worse as yours than before in the video. I had taken mine to the dealership for them to fix it. I thought they did an ok job at first. But after taking it to Troy he showed me everything they ****ed up. I am 22 years old. This is my first vehicle. I didn’t know any better. I now know the dealerships are all scammers taking the easy route to fix stuff. Or they will void a warranty for stupid shit because they feel like it. I wish you luck with your truck. Troy and Shane are good people. They will do what they can to help.
Sent from my iPhone using Tapatalk28a18d4fea893c11bc5b706feeafa161.jpg4f4c636384248957c3e3e75f3946af5b.jpgfaed4b3db1217518df6fb4167459f187.jpg
Yeah lol. As I was pulling the tabs together they busted. The driver’s side came out fine. But the passenger side has been hell.
lol I did the same thing on my jeep, the tabs looked as if you pull them out then slide them out.
But he's right you just need to force it out with a tool. Do your best to not break the housing.
3 hours ago, Texas_Native said:
Yup like Troy said in the video it’s the minerals from rain or even tap water that etches into the paint. I remember having to fix that when I took delivery of my truck. Really isn’t too difficult of a job usually just time consuming since these trucks are so big.
They sprayed the ceramic on, I think that is where all this came from. There is no signs of it running down like rain would've. We'll see...
Sprayed on ceramic? Weird I thought you always had to spread it on.
At the Gm factory I work at every one of the vehicles have "orange peel" paint jobs.
Orange peel is one thing, this is totally different. It sure didn't look like this when I took it to them. There is an acceptable orange peel gage that every auto maker uses.
The start of the electrical side for the Articulating Running Board Installation.
  • Like 3
I'll snap a picture of one of the white Cadillac, besides the orange peel the facia doesn't ever match the body color. (Painted at a different factory)
3 minutes ago, SuperSierra said:
Did anyone get this with their truck? It's a spare battery right?06ab0482eaf85dfa72df16986772d7dd.jpg4e80518c4da3754a264e29372fdf8a9a.jpg
That is the GM-T5 plug. How long has not been hooked up? Have you smelled burnt wiring or anything? Seen any smoke?
Didn’t get one with my truck I bought brand new in 2015
Just got it yesterday where do I put it?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
