LOL I apologise, I could not resist. I was just kidding..
Lol, so it is a spare battery, i didn't get it with my 2016.
LMAO! I was shitting bricks for this guy too. LOL!
Battery for your key fob?  Must be a dealer gift.
Dealers gift was giving us $4500 for a 2005 avalanche. Lol but ya bet they aren't the right size
Jrob - I went with the little Choetech charger off amazon for like $12.99. Took the black plastic casing to get to the actual charger on the inside and that lil guy fit like a glove right under the rubber and plastic in the console lid. I was worried at 1st that the charger wouldn’t be able to charge through the lil rubber mat AND that black plastic part of the console lid but it did. Took a 5/16 drill bit and BARELY widened one of the little holes (circled them in the pic) under the console lid to run the usb cable through. Works great and looks clean for the most part.
On 11/10/2017 at 9:52 PM, jrob56 said:
Which one did you go with? Got new iPhone too and want to do this as well in my console lid.
On 11/5/2017 at 8:23 AM, ChevyRoofer said:
Any pics?
Thanks for the info! Does this look like the one?
CHOETECH Qi Certified T511 Qi Wireless Charger Pad with Anti-Slip Rubber for iPhone 8 / 8 Plus, iPhone X, Samsung Galaxy Note 8 / S8 / S8 Plus, S7 / S7 Edge and Qi-Enabled Devices https://www.amazon.com/dp/B00C40OG22/ref=cm_sw_r_cp_api_6YncAbKBBGQSM
Yea man that’s the one. Guess the price went up a few bucks. But just peel the four rubber feet from the bottom of it,remove the small screws, and take that black plastic casing off to slim it out a little bit
  • Thanks 1
Installed a wireless charger in my console this weekend.
I wont go in detail on the steps as most know how to do it, but when putting the plastic tray back in I used 4 screws to mount the plastic tray back in place. The tray does still sit flush, and has no visual difference or feel than when 6 screws were in. I have used this over the weekend, and it has easily picked up the phone each time it is set down, and remains charging as long as the truck in on.
Below is the charger I used. To access the wireless coil, there are 4 rubber feet on the bottom that you need to remove. This will give you access to 4 screws. Once they are removed simply separate the top and bottom and the coil will come out.
https://www.amazon.com/gp/product/B017KQXO4U/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
that's funny, I just did the same install this weekend with almost the same charging mat on my 2014 sierra.
the one below is a similar model and also works.
https://www.amazon.com/Choetech-T513-Wireless-Charging-Devices/dp/B00JA7HNZO/ref=pd_cp_107_3?_encoding=UTF8&psc=1&refRID=A403PGZ2CXVSJV21119C
Installed a 22" light bar from Amazon this weekend. Mounted on the two brackets that were from the lower valence that i removed. I had to add a 24" piece of aluminum behind so it was mounted to the holes since they were only about 15 inches from each other. It fits perfectly between the two tow hooks too.
0ac32c5c8d6c3e8e7cb9c5de095572f3.jpgFinally finished out my headlight and fog light switch up. Like I said, I went with Alla LEDs for both. Output isn’t bad. Haven’t had the opportunity to use the highbeams that much but it’s a definite improvement.
Edited by FootballCoach53
Did you remove the entire air dam or just the bottom ~1 1/2" piece? I know you said lower valance just wasn't sure exactly how much you took off. I like the idea and location
Sent from my SM-G955U using Tapatalk
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
