3 hours ago, DeepBlue17 said:
Isn't this one supposed to have the sequential turn signals?
It is, that video I tried to post is not the best. The amber lights come on in 3 sections sequentially. They cycle quick though .
Just had 275/70/18 Nitto Grappler G2s put on for the winter season. No rub with a 2.5" leveling kit and they look great!
e2682ed0e1de2ccd948df5bf2eade04e.jpg6be00b2dc2c3e5bb2f2945eea19fd908.jpg71459600dd3b392438f8fd8f92a8b259.jpg
I know it’s not a video and not the best photos but possibly better than nothing. I couldn’t snap fast enough to catch the first signal flash.
Used this harness:
https://www.amazon.com/gp/product/B0009FJ38Q/ref=oh_aui_detailpage_o03_s02?ie=UTF8&psc=1
No splicing of factory wiring at all, just spliced into this harness. The 7 pin connector has the reverse wire necessary to turn on the white backup light.
No splicing at all if you don't care about the reverse light, just plug into the 4 pin for brakes and turn signal.
In the future returning to stock is just unplugging the harness and plugging factory plug back in. Also this allowed me to hide all wiring behind the bumper and still have use of factory trailer connections.
Thanks! I was going to be splicing soon.
One of the amazon reviewers on both the light bar and the harness mentioned this way of doing it, it was much easier than messing with factory wiring. There are 4 white wires that go between the male and female 7 pin connectors on the curt harness, the one that is coming from right in the middle of one connector, and going to the middle of the other, is the wire you need to splice into to get the reverse feature to work.
I'm thinking of moving down rim size from 20 to 17 and going from a 33/12.50r20 mt to a 33/12.50r17 AT
I'm I making a mistake?
Off Road will be better, but on road cornering will suffer a little bit. Truck should ride a little smoother.
If you decide on this move, let me know. I've been contemplating this change too, but don't want to waste their money if it turns out I don't like it lol
Sent from my LG-H872 using Tapatalk
Logic and forum opinion leans towards more sidewall = a smoother ride, but I personally didn’t notice a difference going from 22” down to 17”. I suppose it has to do with the fact the 22s were p rated and the 17s Lt rated. But most of us are buying LT tires since almost all off-road and mud tires are in this category. So it cancels out any benefit :/
8 hours ago, yamaha0343 said:
Same mats I just ordered. Although I went ahead and got the piece that covers the hump as well.
Edited by T_ClarkEx39
Got rid of some chrome. 68d919cd96afe8eed5b25fc7925cefcd.jpgce1e46bd4e8261e61bd2b3d934d72f33.jpg1bf77eaecdc8c40aa4ab60590a3fb15e.jpgfee9d6bb8d0eb12a5fa3efc6b0cefb82.jpg
Sent from my SM-G930V using Tapatalk
  • Like 3
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
