Did you remove the entire air dam or just the bottom ~1 1/2" piece? I know you said lower valance just wasn't sure exactly how much you took off. I like the idea and location
Sent from my SM-G955U using Tapatalk
I took the whole thing off
Over the weekend, I drove up to the Big Bear area and home again, out on Friday and home on Sunday.  Cleaned out the truck to make room for a couple that went with us.  Only had a small bit of traffic when I was going from I-215 SB to SR-210 EB, on the loop.  Way home was smooth all the way home.  Now to wash/vacuum the truck one these mornings.
Orange peel is one thing, this is totally different. It sure didn't look like this when I took it to them. There is an acceptable orange peel gage that every auto maker uses.
Here is a Cadillac with the mismatch paint e6c556d6f1a6a1eff3dede30d8d7d17a.jpg
What is this orange peel you speak of??
When you look at the reflection of an object in the paint and it has the effect of looking rippled like an orange peel 361e85dc1ff582b653f0fc6f289b839f.jpg
300 + mile round trip to Peoria Illinois to pick up a few cases of Red Line Oil D6 trans fluid and a Genesis shock gauge from Hoerr Racing. Peppers upcoming 50K service. There's a $400 dollar day.
44 minutes ago, Eddie 70 said:
Curious as to how this wires in. Did you have to cut factory wires?
Opt7 has a y splitter that plugs into the 4way on trailer
Used this harness:
https://www.amazon.com/gp/product/B0009FJ38Q/ref=oh_aui_detailpage_o03_s02?ie=UTF8&psc=1
No splicing of factory wiring at all, just spliced into this harness. The 7 pin connector has the reverse wire necessary to turn on the white backup light.
No splicing at all if you don't care about the reverse light, just plug into the 4 pin for brakes and turn signal.
In the future returning to stock is just unplugging the harness and plugging factory plug back in. Also this allowed me to hide all wiring behind the bumper and still have use of factory trailer connections.
Edited by GOMD
My JL console stealthbox arrived today. I need to pick up an amp wiring kit and will try and knock out the install on my next days off.
Edited by 05cyclone
  • Like 3
15 minutes ago, 05cyclone said:
I can't wait to hear what you think of this.  Ordering one soon.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
