That is so awesome. Didn’t think any of you guys on the forum would actually watch his videos. I got to see mikes McLaren up close and personal today.....! Troy is an awesome guy. He will be the only one touching my truck to do any detailing/ coating work.
I’m so jealous!!!!
Was so sad to see your beautiful truck be messed up like it was. You definitely lucked out being close to Troy. Looks great now though!
Got wheels mounted on my Black Rhino Warlords today!
Comparison
After
3 hours ago, chrispassas21 said:
You the one from Michigan getting it shipped to him??
Yes, I 'm the one from Michigan, just got done texting with Shane. I spoke with Troy and Shane both today on the phone at separate times, sent pic's to both as well. I'd like to take the truck to them, don't know of any other reputable shops near me to turn to. I can't believe this is even happening to my truck. Not sure how it will end up with the current shop I am dealing with....
On 11/4/2017 at 9:06 PM, BevoXV said:
Installed a wireless charger in the jump seat. Took 5-10 mins tops. Eventually might hard wire to the cig lighter but for right now just running off the USB port. Thanks to Chris from the forum for the quick how to video
Which one did you go with? Got new iPhone too and want to do this as well in my console lid.
5 hours ago, FootballCoach53 said:
I have no clue how to get my passenger fog bulb out. I’ve been searching and googling all day. The clips on the top and bottom broke off. I can’t figure out if that means I’m SOL and need to take out the housing, or if there’s an easier way.
Use a flat head and push the release clip up and pull on the housing at the same time.
You’re a damn genius. I’ll be doing that tomorrow!
That’s awesome to see my input helped make your decision to go to Troy!
I do hope your truck works out, but I was on the phone with Shane long before I seen this here. I seen the video first with Troy, take a look at his video about your truck, you'll see my reply. Unfortunately, my truck is worse than yours. I know it's no contest I would want to win, but, they will need to strip the entire truck from bumper to bumper, roof to running boards, before they can do anything else. All the while, hoping my clear coat doesn't get burnt through, yet again. It's going to be a very expensive endeavour. It's been mouths of dropping off my truck, driving some pos rental for days on end. If I end up taking my truck to Shane and Troy, they could make more videos on what NOT to do, and what it will take to fix it.
Here's a quick pic, the entire truck looks like this...
Lol did you pull the two tabs rather then push in?
Don't let the light fool you, as you move the sun across the window or paint, you can see all of what looks like water spots over the entire truck. I think it came from spraying the truck, and our driving it in the rain to soon, I'm no expert,bff that is why I contacted ones who have proven themselves, and have shown proof Very publicly...
Yeah lol. As I was pulling the tabs together they busted. The driver’s side came out fine. But the passenger side has been hell.
Edited by FootballCoach53
It was 27* and snow flurries here yesterday. I went and got the truck oil sprayed. Local guy to us does a great job. The hardest part is leaving it parked in the street for a few days so it can drip off. I worry too much about being a victim of hit and run. Lol.
Comparison
After
Look's Good - HOW do you like your running broads .
Yup like Troy said in the video it’s the minerals from rain or even tap water that etches into the paint. I remember having to fix that when I took delivery of my truck. Really isn’t too difficult of a job usually just time consuming since these trucks are so big.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
