Where it winds up. I keep the gallon jug and pull the old fluid to this jug. Add the new fluid from quart bottles because I found them quite a bit cheaper recently.
Texas heat unfortunately has me getting up really early or working later into the evening to mod the truck. Sorry for the crappy pics but just finished my install of the new heated steering wheel, and leather shifter
Edited by MHPrior80
  • Like 3
Where’d you get the wheel?
Ordered it from GmPartsNow.com along with the shifter lever. Had a promo code so it was a good deal on my end
How difficult was the install?
First wheel swap took about 45 min. This is my second wheel swap. Took 10 minutes or so this time
Wow...very cool. You guys are adding some great features.   All I did was replace the factory floor liners with aftermarket. Ha. Side steps will be in two weeks. Loving my new Silverado.
Besides the steering wheel itself, what other parts are needed to complete this install
I finally bought a foam gun from amazon, I have to say it’s worth the money438946636148ef901f626e396d2daebf.jpgd4bfb6608ef0748c2ab4c2e7922b6eb4.jpg
Love my foam cannon too987b4948dc1fde2f013fc2663769f728.jpg1101f1d1f505bddecb9f82aafd625fbd.jpg
I received my gears today from ECGS; 4.10s.
Truck goes to shop on June 11th to get moved from 3.42.
How much does this usually run. The cost for gears and install?
A new clock spring
Gears cost me $900 shipped and the labor to install is $800.
That’s not bad, I would of guessed more.
What shop in Jacksonville is doing this?  That's cheaper than I thought.
It was my 3rd bid. The shop that did my lift quoted me $1800 in labor. Another shop in GA 60 miles away quoted me $1000. This shop is local and quoted me $800.
North Florida Off-road on Beach.
Extreme wanted $1800 in labor.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
