Foggy windows
MJFlores
Fog is normal on a new vehicle. Part of it is the outgassing of the new materials leaving a film on the windows. Mine dont fog anymore, but I also made sure to clean my windows once every week for the first month or so and I keep a dry cotton towel in the truck to wipe the window down as well. Takes a bit, but once the outgassing stops the fog/haze should lessen and not fog up as much.
I have not experienced this with any new vehicles I bought in the last 25 years. And I live in humid Florida.
Typically you will get foggy windows in warm weather if a vehicle leaks water and carpets get soaked and then the water evaporates and gets trapped inside the vehicle.
I ahve noticed this on every new vehicle I have owned for the last 15 years. Try cleaning your windows, the more contamination you have on the windows (outgassing, smokers film) the easier it is for the wondows to fog over.
the worst thing you can do is put any "shine" chemicals on your dash. that causes this more than anything. Just clean your dash with warm water.. you don't have to "protect" these dashboards of today..
Had this same issue with my 8th gen civic, it usually defogs better with A/C on to reduce the moisture content captured in the cab. This happens a little more often in our trucks because of the already mentioned good cabin seal.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
