Hello all
im looking for the Flasher location in my 2013 silverado
i installed all new LED Bulbs (except Headlights) from Superbrightleds.com
they are all working great but a common known problem with leds is that they dont use as much of a load as regular bulbs causing the system to think that the bulbs are out. there are relays that can be bought with no minimum load requirments so what i am asking where can i find this relay so i know what one to buy. i have checked the manual for this and there's not even a relay for the signals under the hood or in the panel in the cab that i could find.
any help/info would be appreciated
Thank you
There is no Flasher on the '13s - it is controlled by the BCM if I recall correctly. You need the resistors to make the system think the ligts are working correctly. The upfitters version of the BCM has the light out warning disabled.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
