i just installed my rough country 2" leveling kit on my 14 z71 4x4 and i saw somewhere another member saying that he had to cut a bolt because it was hitting his C.V. shaft but couldn't find the thread as im pretty sure it was in the middle of a picture thread or something. well when i installed mine today i had to do the same. you have to cut the rear most bolts that bolt the lower shock / strut assembly to the lower control arm other wise it will hit the C.V. shaft. i just emailed rough country about it and we'll see what they say. just an FYI for anyone who wants to put the RC kit on be aware that this is an issue. other than that issue it was fairly easy to put on.
anyone else put on a different kit that can chime in and say if they had this same issue?
here are some pics. gonna take some better pics tomorrow with a DSLR camera.
i measured before and after the install and it came out to just about 1/16" under an exact 2" lift.
You shouldn't have to cut the bolt. Did you buy the correct kid for your truck? They have two kits, one for steel control arms and one for aluminum. I believe the bolts are different lengths for the kits.
I have the rough country lift with no issue installing it. Take pic of the bolt you cut.
i will take a pic tomorrow.
EDIT: Do you have a 4wd or 2wd?
Correct. They offer two kits, one for the steel control arms and one for the aluminum. I have the aluminum control arms and ordered the kit for the aluminum control arms. i tripled checked before placing my order. i literally followed the instructions step by step as i wanted to be 100% sure i didn't miss anything. i even disconnected the battery before working on my truck which i NEVER do. i read on a f150 forum that some of their issues with their EPS racks is that when doing the leveling kit and not disconnecting the batter it messed up the rack. i am not sure if there is any correlation but i didn't want to risk and it and it only took me 1 min.
Edited by thewhitestallion
Mine is 4x4. Did you installing the bolts down through with the nut on the bottom?
you cant do it that way because: 1. the instructions say to install it with the head of the bolt on the bottom. 2. you cant put the bolt with the head on top because the C.V. shaft is right on top of the rear most shock bolt. the only way to install the bolt with the head on top and the nut on the bottom is to remove the axle from the hub and then put the bolt in. however, doing it that way will require you to do that every time if you want to remove your shocks / strut assembly.
x2, you shouldnt have to cut anything
I completely agree however, I did have to cut the bolt. there was no way it was going to work without cutting the bolt. i had to cut the bolt about 1/16" - 1/8". so now the head of the bolt barley pokes through the top of the nut.
I'll wait for pics, but I have the steel suspension so mine is obviously different. I was able to put my bolts down through.
Edited by LTZ2014
Mine cleared and don't hit the cv shaft ...... U would have to get serious air to do any damage to the joint .....put head on bottom with washer and washer with nut ......worked great for me ....dnt forget to do an alingment your toe is going to be off .....
Edited by Bigman73
yeah im getting an alignment tomorrow.
That's weird, I installed the RC 2.5 lift kit, and I remember the instruction was to install bolts with the head down.
I know you said you have leveling kit, but the lower spacer is basically the same!! Take a look at the instructions for the 2.5 lift kit.
this is the front bolt. (original length)
Rear bolt that i had to cut
top view of the bolt. as you can see the CV shaft covers the bolt so in order to put the bolt in with the head of the bolt on the top and the nut on the bottom you would have to remove the shaft from the hub.
here is the picture from the instructions that come with the kit.
af19e2c8-bffc-4b07-b050-49b369d9da7e_zps
EDIT: if you look closely in their photo the bolt does not have any extra thread after the nut like the ones i was supplied. like i stated earlier i had to cut approx. 1/16" - 1/8" of the top of the bolt. not really a big deal but i wasn't expecting it and the kits literally says "no drill (which is true) and 100% bolt on". just thought i would post this up in case anyone else wants to level their truck they will already know and expect it.
if you are reading this and are about to install this kit make sure to try the bolt first to make sure it fits. don't just cut two bolts and then your bolts be too short.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
