I wanted to hear how my truck will sound if I played with the exhaust adaptive valve, so I took a 2" clamp, turned the valve 90 degrees and clamped it really well.
It sounded nice when the exhaust was cold, took it for a short drive and noticed the tone got better when the exhaust warmed up, slightly louder, defiantly not a $1k exhaust catback sound, but hey, it's FREE!! or almost free if you don't have a 2" clamp laying around.
I'll leave the clamp for a few days, if I like the sound I might as well take that dumb valve off.
Thought about passing this tip for anyone who's considering a catback or leasing his truck, this mod is totally reversible.
On a side note, I searched all over the forum about the tailpipe diameter for the 2014 6.2L, and found that it's supposed to be the same as the 5.3L, which is about 3" or 2 7/8", but when I measured mine, it was 3.5". Did GM changed the exhaust on later builds or what?
The kinda free mod I used for my truck was a pipe cutter to remove the stock muffler. All we had at the time and then a turn down tip for $12.00 and epic exhaust lol.
  • Haha 1
Remove the muffler add a pipe, sounds good not to loud quiet at cruise. I left everything else you can always do more later. I even left the flapper for now. Cost less than a tank of gas.
Good thread on the muffler delete-
http://www.gm-trucks.com/forums/index.php?/topic/154538-Muffler-Delete
Here's a video link to mine cost me 40 bucks-
%20%20%20Sent'>http://youtu.be/mGAX4_Oi9PI%20%20%20Sent" rel="external nofollow">
Edited by Dj0nes
UPDATE: I took my truck to a local exhaust shop and chopped off that valve, sounds nice! Not bad for $30.
What is the purpose of the flapper valve? Are there any negative effects removing it or locking it open?
It's there to quite the drone when the engine goes to V4, and also makes the exhaust slightly quieter but looking at how it's designed, it's very resrtrictive. The only effect of removing it is slightly louder exhaust.
Thanks for the info
Will removing the flapper valve void the warranty?
Flapper valve warranty.....
  • Like 4
Clamp mod performed! Nice lil bit of additional note too! Feels like a shot of nitrous. LOL :driving:
I clamped mine several weeks back however, I recently took it off.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,881 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
