wrong temperature
motrcop931
Is it perhaps showing C instead of F temps.maybe the owners manual tells you how to change that. Other wise it's off to the dealer for you
Mine was stuck at 69 while I ran errands for 45 minutes today. Maybe it really was 69 outside, however I thought it was odd is stayed 69 the entire 45 minutes.
Wifes new Chevy had an issue like that. Temp indicator loved 59 degrees. All the time.
Changed the sensor and the first day it worked like a charm.......quick readout of actual temp.
Then back to 59 degrees for the first 5 minutes of run time........then it reads correctly.
Its been like that for 6 months now.
Can you say......CRAP OUTSOURCED PARTS?
Yeah mine doesn't work properly when it gets below -30 Celsius. It's like it hits a wall and is like "WHY ARE YOU EVEN OUT DRIVING RIGHT NOW?" My '07 and '13 were the same.
did you unhook your battery for anything? If so... it takes about 20 min of continuous driving for the temp to re calibrate.
69...maybe your truck was telling you something. Sorry...back to your regular scheduled forum.
I don't know? This morning, it was on 68. lol!! It's working now. It's up to 82 degrees. Like I said, maybe it was 69 degrees the entire time I ran errands yesterday.
If you didn't unhook your battery like GMC-AT asked, you probably should. Disconnecting for about 10 mins will let all the truck's electronics reset/reboot. Doing so has been known to fix some glitches... it may not work for you, but it can't hurt.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
