Wheel Spacers
Has anyone added wheel spacers to their 2014 yet...Just wondering peoples opinions on them. Pros vs Cons....I don't really know much about them...I wouldn't mind my tires peaking out a bit from the wheel well.
Cheers to everyone!! :loser:
I had them on the rear of my 2012 so that they were even with my front track width after installing the lift. I ran BORA 1.75" spacers. They're the best on the market imo
If your tires stick out past the fender then you will massacre the paint on the body and behind each wheel due to the fact that rocks stick in your threads and gain momentum as the wheel spins then get tossed directly at these areas. Just an FYI... That's the reason people upgrade tires and wheels but also add flares. Really on a stock setup it will look funny and it's pointless, also it adds stress to the suspension parts/front end.
Wheels spacers are not a good idea in my opinion. I've read about them breaking off lugs and then making the wheel fall off a vehicle....
Ive seen them crack and cause the wheel to come loose. I wouldnt touch a spacer on my own trucks.
Sent from my LGL86C using Tapatalk
They are safe as long as you get good ones. I ran rough country on my last truck. It had 24" wheels and 37" tires. I had 0 issues.
It's all about personal opinion and maintenance. I've run them on 3 trucks, never a problem. Get hub-centeric spacers, re-torque every rotation and you shouldn't have a problem.
I'm running 1.5" hub-centric spacers on my '14 now, no issues.
Where did you get yours from?
  • 9 months later...
I may be adding the ready lift 7/8 bolt on spacers, from what I am hearing with that size you have to trim about 1/4" off your studs to fit them. But its perfect size to push the tires away from the UCA but not too far that's its noticeable. anyone use these, ( besides GMC_dude) comments/reviews?
I ran 2" rear spacers on the rear of my 08 Duramax to bring the rear out level with the front. They were on the truck for 100,000km and that was a 3/4ton that pulled a 6000lb trailer occasionally.
Never had one come loose or any issues at all. I wouldn't hesitate to run them... as long as they were quality spacers, torqued properly, and so on.
I have heard horror stories about the cheap "slip-on" 0.25-0.5" spacers that just slide over your existing studs though, so I'd be weary of them. I've heard of them breaking, miss-aligning, causing balance issues, etc...
As for causing excess wear on front end components, it's no different then running offset wheels... so I wouldn't let that bother you.
I ran 1.5" spider tracks wheel spacers on my '07 grand Cherokee with a 3" lift and biggest tires I could fit. As someone else stated regular re - torque at each rotation and spending money for good ones is key. Mine were listed as hub centric and wheel centric made from billet aluminum with an anodized coating. I had absolutely no issues with them at all. Put probably 20k on them before I sold it. Biggest pain was finding some one to overlook them during inspection time. Pa. Requires yearly inspection and they are illegal for Pa. vehicles.
I just posted a set of these exact spacers in the For Sale forum if anybody is interested in a discounted set
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 759 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
