Please post pics of your '14 Sierra with 24" or 26" rims
I can't decide if I want 24's or 26's so I'm hoping to see some pics of others with 24's and 26's. I'd also like to know width and offsets of your rims and if you've had any trouble with rubbing, especially with 26's. Thanks!
  • Replies 38
These are 26x10 not sure what offset was though. No rubbing at all. I put them on the day i bought the truck then only had them for a couple days.
I'm sorry, but tell us the truth about how your truck rides with those 26" rims and thin sidewalls. I have to believe its a hard ride that is not forgiving in any form i.e. dips in the road, speed bumps, potholes, etc.
Don't take it wrong, I believe everyone has the right to roll with their own styles, just curious.
Looks good! Are you going to lower it any?
And if you get a chance, will you post a picture of it from a rear view? I'm wondering if the 10" wide wheels stick out the sides any.
No rubbing at all? You can turn the wheel all the way in both directions and no rubbing? That's awesome.
Yeah you're right, not many go any bigger than the factory 22's. I think GM did a horrible job with choosing the design of the wheels. I like the brushed aluminum 20's- that's what I got (pictured) but I wish they would've had some 22's designed similarly.
I'll probably end up doing a 24" wheel with a decent sized sidewall (but still low profile) that way I'll get the larger wheel look without sacrificing too much ride quality.
Note: my truck is lowered a little over 3" in the rear and there's still a lot of gap to fill.
Take a min and browse through this topic: http://www.gm-trucks.com/forums/topic/154469-post-pics-of-your-2014/ ...though I don't believe 24-26" wheels are very popular on the forum. Most stop at 22"
Good looking truck too! I'll be honest- I wanted to get an LTZ Z71 crew cab and put a lift and big tires on it, but I just can't afford all that. But I wanted a truck, and I wanted a new Sierra, and I want to have some fun modifying it, so I went the other route- 2WD and lowering it and going to install bigger wheels.
If the owner of this truck happens to see this post somehow, I'd love to hear about what he did and if he's having any issues with it. I like the looks of this one, but it's a little bit lower than I want to go.
Nice rubber bands
Nice rubber bands
One will notice a slight difference when they go to a lower profile tire, but ultimately, the suspension is taking the force of the bumps in the road. I don't want to do a super small low profile tire because I don't want to risk damaging an expensive wheel, and I'll still have pretty much factory ride qualty. It'll be more noticeable with pot holes and aggressive bumps, but there won't be any difference in the feel of humps and speed bumps.
I don't think wikidbwoy cares very much. His is a show truck. You should see the finished product
Sent from my LG-D800 using Tapatalk
Here's his finished truck
As I stated in my post, everyone has their own, I was just curious/asking. Not my style e.g. Low rider stylin but I admit the finished product or at least what's shown to be above certainly looks better than the previous photos of the truck at stock height with the 26" wheels.
I only drove maybe 50 miles on those 26s but it didnt rub in the back. I dont have any more pics with the first set of wheels sorry. I live in California and the truck was in Houston and was bagged before i really got a chance to drive it stock. With the bags im running 26x10 with 295/30/26 and 26x12 with 305/30/26. Theres no rubbing now because they cut a lot to make it all fit and narrowed the rear end also. The truck was drivin from Houston to Vegas for Sema and then to Bakersfield. The truck rides really smooth and doesnt bother me at all. Its not everyones style and I get a lot of negative comments online but to each his own.
I respect your choices. BTW, where did you get the fender surrounds?
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
