Nice buy. I'm a fan of rock auto. Great site.
Definitely. They've been the cheapest place for about all of my parts so far.
I always check there and Ebay. Rock Auto is usually the cheapest. And a great resource for part numberers
Sure is. I think I'm going to order a power steering pump from Rock Auto too sometime before the motor goes in. Mine makes a lot of noise. I also need a new Drier/Accumulator, but I need to call the dealer for part numbers first.
The funny thing is that your parts list above is right about a single new monthly truck payment. Except you don't have to make 60 or 72 of them...
  • Like 4
Lololol
Coming along great! Doing the motor install youself?
Sure am. Dad and I will be doing the swap.
Haha! Yea I know what that's like. My last truck payment was $575 per month. Never again.
I could only imagine [emoji17] lol
Haha! I didn't say there was anything wrong with it, it just gets old lol! Gotta pay to play as they say.
Did a few minor things today. I removed the oil dipstick tube, exhaust manifolds, spark plugs, spark plug wires, and the waterpump.
I envy you for being able to work on the engine outside of the truck!
Haha! I know man, it's great! [emoji1]
Dropping in a new trans with it or nah? When I get my performabuilt trans rebuilt under warranty you can pick it up and buy it off of me. It will already be in PA lol
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
