They're 18" Methods... do they are a +18 offset
They have 3 offsets in the 18, +18, 0, and -12
Edited by jrob56
in the 6x5.5 bolt pattern they only have +18 and -12 for those particular wheels.
My mistake on that.
But those are +18 for sure. The -12 stick out way more than that.
Edited by tyrich88
My mistake on that.
I got yeah, was thinking they were 0 just by looking. Didnt know they didnt have 0 in 18.
So here she is.
3 inch level
20x9 +1 fuel.couplers
Toyo at2 ext 285/55/20
Curious on what tire pressure I should run. Currently at 36 all around...also what is a good cheap tpms reset tool
a7a4cc8975d127735a64efd93f5dcf89.jpg8ad1419bd2dafd2f085450b950bbb0a4.jpg8c1b22fbf1174dfc8cea4fddb6450f06.jpg0237328233799f8fa416c320182cf5c2.jpg
Sent from my Nexus 6P using Tapatalk
  • Like 5
Supersierra,
Is there a way to see what tpms they are compatible with. Got the wheels at custom offsets and the put in uvs3011 sensors. Just want to make sure they will match up
Supersierra,
I wouldn't see why not, if you told the shop what vehicle the tpms are going on. I personally would message the seller of the scanner and just ask to make sure.
K I just looked. Looks like the sensors included work off of 315 MHz. On Amazon the description says 315 and 433 MHz so I'll assume it should be good. Thanks bud
Edited due to I had put the wrong frequency. Now they are correct
Edited by Jeff5347
K I just looked. Looks like the sensors included work off of 315 MHz. On Amazon the description says 325 and 422 MHz so I'll assume it should be good. Thanks bud
Don't worry about it man, I need to order the same one for myself I bought new tpms and have yet to put them in.
Edited by SuperSierra
Don't worry about man, I need to order the same one for myself I bought new tpms and have yet to put them in.
Fixed my previous post. I put in the wrong freqs. Edited the post for the correct freqs
But any advice on tire pressure to use on the at2's? At 36 now
So here she is.
3 inch level
Truck looks real good man! How you liking your Toyos?
2014 GMC Sierra All Terrain 20x10 -12 offset Fuel Mavericks with All Terrain tires 305/55/r20 has Rancho Quick Lift leveling kit Struts on the front
SuperAllTerrain
What tires are those? Kinda look like the Hankook AT tires, but can't too good & good do you like em?
thanks alot. So far I like em alot. Only a few miles but actually ride pretty darn good
Edited by Jeff5347
So here she is.
3 inch level
What level are you running?
3 inch motofab front and 3 inch blocks in rear
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 405 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
