They're 18" Methods... do they are a +18 offset
They have 3 offsets in the 18, +18, 0, and -12
Edited by jrob56
in the 6x5.5 bolt pattern they only have +18 and -12 for those particular wheels.
My mistake on that.
But those are +18 for sure. The -12 stick out way more than that.
Edited by tyrich88
My mistake on that.
I got yeah, was thinking they were 0 just by looking. Didnt know they didnt have 0 in 18.
So here she is.
3 inch level
20x9 +1 fuel.couplers
Toyo at2 ext 285/55/20
Curious on what tire pressure I should run. Currently at 36 all around...also what is a good cheap tpms reset tool
a7a4cc8975d127735a64efd93f5dcf89.jpg8ad1419bd2dafd2f085450b950bbb0a4.jpg8c1b22fbf1174dfc8cea4fddb6450f06.jpg0237328233799f8fa416c320182cf5c2.jpg
Sent from my Nexus 6P using Tapatalk
  • Like 5
Supersierra,
Is there a way to see what tpms they are compatible with. Got the wheels at custom offsets and the put in uvs3011 sensors. Just want to make sure they will match up
Supersierra,
I wouldn't see why not, if you told the shop what vehicle the tpms are going on. I personally would message the seller of the scanner and just ask to make sure.
K I just looked. Looks like the sensors included work off of 315 MHz. On Amazon the description says 315 and 433 MHz so I'll assume it should be good. Thanks bud
Edited due to I had put the wrong frequency. Now they are correct
Edited by Jeff5347
K I just looked. Looks like the sensors included work off of 315 MHz. On Amazon the description says 325 and 422 MHz so I'll assume it should be good. Thanks bud
Don't worry about it man, I need to order the same one for myself I bought new tpms and have yet to put them in.
Edited by SuperSierra
Don't worry about man, I need to order the same one for myself I bought new tpms and have yet to put them in.
Fixed my previous post. I put in the wrong freqs. Edited the post for the correct freqs
But any advice on tire pressure to use on the at2's? At 36 now
So here she is.
3 inch level
Truck looks real good man! How you liking your Toyos?
2014 GMC Sierra All Terrain 20x10 -12 offset Fuel Mavericks with All Terrain tires 305/55/r20 has Rancho Quick Lift leveling kit Struts on the front
SuperAllTerrain
What tires are those? Kinda look like the Hankook AT tires, but can't too good & good do you like em?
thanks alot. So far I like em alot. Only a few miles but actually ride pretty darn good
Edited by Jeff5347
So here she is.
3 inch level
What level are you running?
3 inch motofab front and 3 inch blocks in rear
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 326 Guests (See full list)
