Voice Recognition doesn't always activate
I have a 2014 Silverado Z71 with the 8 inch touch screen. Nearly half the time, my voice command function will not activate. When I push the voice command button on the steering wheel, I receive a message that reads, "voice commands not available for selected language". The selected language is English. Also, the voice icon on the touch screen isn't illuminated. When illuminated, it works fine. The only way I can get it to work is to turn the truck off and remove the key, then restart. I was wondering if anyone else has experienced this problem? I'm sure it's a software issue. Can my software be upgraded or reloaded at the dealership? Thanks.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
