Def low gauge on 2015
  • 4 weeks later...
The 2yr 24k miles covers the def. Max oil change is 4 times. However the def doesnt say anthing about the number of times. I can only assume when ever the light comes on to take to the dealer and they will top it off. Luckily for me theres 2 chevy dealers one each way north and south no more than 15 miles each.
  • 2 months later...
My dealer advised me they will only add Def during a visit for Service...
My understanding is the dealerships are no longer being reimbursed for Fuel or DEF from GM.
Mine gave me an early warning of 20% def left with 2500kms driven and 80% oil life left. For $83000 they couldn,t put in $15 worth of def really.
Went back to mine to get the def tank filled under the 2 year/ 24000km program and was politely told they never heard of this being offered by GM, service writer said i needed to talk to my salesperson, what a joke. At 11% tank level my dic said i could only go 160kms. I filled the tank at this p[oint and it took 23.5 litres of def to refill the tank to the top of the filler neck. Still have to have a lil heart to heart with my sales person.
  • 3 months later...
I read somewhere that you were not suppose to fill it to the very top b/c of potential freezing. the article said that when you get the def low (1000) miles left warning, to put in 31/2 gal and that will take care of it. My 1st warning came at 1600 miles. I put in 3 gal and it is probably gonna warn me soon. Oil change is at 17% and def is around 19 % level. I have a 2015 HD 2500. I live in Indiana.
  • 1 month later...
Mine went 1600 miles before I got the message. I put 3 gal in it and the level got down to about 18% at my 1st Oil Change at somewhere around 6000 Miles. Def will freeze in cold weather so that may be why some dealer don't fill them until they sell them. The other possibility is that GM allows x number of dollars for dealer prep and by not Topping off the Def . That adds to the dealer's profit margin. I am betting that if you were to take it back to the dealer and called them on it, they would top it off with no questions ask. I am betting that most of us don't follow through with it and just buy our own. The dealers are like Obama. Spreading the wealth. :nopity:
Freezing def does not hurt it. The heater can thaw it fast enough to meet the engines needs.
Dealers not filling the tank at delivery is by far the most common complaint from new owners on the diesel forums.
As others posted, the dealer is supposed to fill it at time of delivery.
I asked my dealer today about this and they stated the factory only puts 2 gallons in before they ship them out. During the PDI, they do fill them, but are not required to, just like the gas/diesel. GM decided to stop paying for the fuel, so now it's up to the dealer to eat that cost or not give any fuel..
The Dealer is responsible for maintenance including up to 4 oil changes and the DEF for the first 24 months. I went round and round with a Texas Dealership. I wound up contacting Chevrolet and they confirmed the DEF was to be included.
GM techlink article would suggest they are supposed to fill def tank just before delivery.
Big difference between adding $15 worth of def and the cost of a tank of fuel.
Many dealers add (or try to add) some sort of service fee onto the deal. They have no good excuse for not filling it.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
