14 Sierra steering rack clunk, rack needs replaced
pj8556
symptoms on my 14 Sierra 4wd, I have added 4" lift and bigger tires. \
Loud clunk heard and felt, and intermittent binding when turning hard to the left. So, a shop owner friend and I removed the inner tie rod boot and found loose parts, broken parts, metal shavings, something came loose And the steering rack is puking out parts and that is what's causing the noise binding, the loose and broke parts are causing problems with the articulAtion of the rack. More than likely is not caused by the lift cause the tie rods are not being stressed to extreme angles at all. And all the loose broken bushings and metal shavings are on the steering rack side of the tie rod, nothing changed there. Didnt even look at the driver side for damage. Goes to dealer Thursday, needs a new steering rack. And I better not get warranty coverage flack! Anyone else??
I have been hearing a loud clunk noise when I turn right all the way to stop, to backup.
Did you have to take the boots off to see the damage. I was focusing on this area as part of my front steering vibration. I did not want to void my warranty by removing them to inspect!
It was known that some of the steering racks were bad on the trucks and several members have had them replaced under warranty. They might give you flack for the lift, but thats your own fault. The steering rack may have been fine before the lift, but the added stress from the lift components and bigger tires/wheels, might have put it over capacity, causing it to fail. Gotta pay to play.
Good luck.
Is there any chance you could post some pictures of the damaged steering rack.
thxs.
Dealer had no problem diagnosing the problem, some sort of retainer coming out of the steering gear (theres a rod that comes out and connects to the inner tie rod) well something came loose and parts started coming out of there inside the inner tie tod boot, these loose parts were causing the binding and noises. definitely a mechanical failure, dealer does not think its related at all to the lift or bigger tires. he's ordering a new steering gear, because its a new design in demand and this is not the first problem with this new steering rack, GM wants to make sure it cant be fixed other than replacing the entire unit so there were some questions but its looking like warranty will cover it. Dont even want to know what parts/labor will be on this job.
I'm getting pretty frustrated with this truck, I want to like it... its just been problematic: broken moonroof assembly from the factory, 3 weeks in the shop waiting for parts while my roof and interior are torn apart, and now this, complete steering rack replacement at 4000 miles, not minor issues.
US parts and US assembly would fix alot of this in my opinion. I hate to say it but I'm thinking about a Ford more and more.... and thats saying something, I have always been a GM guy through and through.
I will post pics if I can get some, truck is in the shop now.
Sometimes things like this can be caused by someone not installing an E clip properly in the critical location. This emphasizes the need for consistent quality control at all levels.
Steering rack is assembled in the US. Assembled in Saginaw, MI.
You can relax the quality control no matter where the part is made. Apparently this is what is happening. To lower the costs, something has to give.
Oh my, really. Failures happen no matter if assembled here or outside the USA. As long as humans are involved in the assembly process the room for errors will be there. Get it fixed and move on. If it bothers you or you are worried then sell the truck and buy foreign. I hate to tell you this Ford has just as many issues as any other manufacture.
  • 10 months later...
hey guys, I think i am having this steering rack issue as well. it pops/clunks when you back up and turn the wheel and just sounds terrible. Also im not sure if this is a related symptom but the steering wheel will pull to one side after i make a gradual turn, but then go away. really strange.
I do have the rough country 2.5 lift in the front, not sure if that aggravated it or not. I guess ill have it looked at next time im in for an oil change.
  • 2 months later...
going in on tueaday to be looked at. sounds like its getting worse and worse, even hitting small bumps at low speeds it makes a terrible clunk. I really hope it will be covered under warranty and they dont say its due to the lift.
Those of you with this problem should report it on NHTSA's web site. If the steering suffers a lockup or loss of ability to control the wheels at 65 mph it would not be hilarity that ensues. It sounds to me that this has the makings of a recall, particularly with the tacit admission -- they're redesigning something, right? -- from GM that there's a problem. With enough reports of the problem it's much easier to get the recall ball rolling.
I have been wondering about the safety behind this problem and wondering why a recall hasnt come out. It doesnt seem to prevent you from turning the wheel, but wonder if after a while it might have that effect. Id like to see some pictures or a diagram of exactly whats going on.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
