. Does that mean I got a WT?
Based on your info and the picture of your truck, I would say yes, but I'm not an expert.
Yeah it basic tuck the real world saying. I guess it is wish it said it is WT. Kind of lame a work truck with no remote start. Think about it. It out in the cold all the time. Horst environment and different applications life style and ways of needed a truck for. And warming up that motor for a greater load, Who want to sit in a truck being all cold LOL. Who in the right mind would let some fancier model for a 50 $ cheap technology go to waste.
Blows my mind with all the electronics out there that could improves sales.
I am spoiled by the OnStar remote app. Lets me start my truck from any range :)
They don't use WT for Sierra anymore, if it has no letters (other than HD), it means base trim.
As for remote start not being standard, blame the tree huggers, I guess. :dunno: Some areas have by-laws that discourage running them.
My vote would be to ask the dealer if they can add the factory system, and only go aftermarket if they can't.
Ok guys I found out.. If you have a AQQ remote system it will just work as keyless system. You would need a AM1 - AP8 or AQP8 in your RPO. Another word you would need a LT/LTZ SLE or SLT ECU remote module system. I heard one guy said you would have to plug in the fuse and add few wires to the remote command module it order for it to work. I don't know what part number that would be. But I just wasted 190$ plus 60 bucks for programing my remote I thought they knew what they were doing. Pretty much disappointed.
I hope I can return the remote with the latch packages back to this guy on ebay
If you have a regular Sierra or a Chevy 2500HD or 1500 it has no start remote. Now if you had it order from the manufacturer with the remote packages it will add that. You can add it on the truck but you would need to contact the manufacturer from GM they could provide the little computer for the Keyless remote entry with start.
Don't be fooled by the www.gm. owner center they will just give you a FOB remote with no RCU.
So you are better off going to Best Buy or some car Audio place to add in a Viper with a remote. They have the diagram to add a remote start and better car/tuck alarm system.
Yes that is correct. But Also the wire does tell the remote system to fail when the hood was pop open from being started. So you won't be robed. I thought it was a pulley that let you remotely pop open they got that motor for that latch it on ebay it the same way for that unlock tailgate. Pretty much it.
Thanks guys. I took my truck back up there at the dealership to have my alignment fix this is my 2nd time hopefully they fix it only got 481 miles on it. it pulls to the left real bad
If all you have is AQQ... then you need GM part# 22997089 and you need it installed at a GM dealership so that they can reprogram the BCM and new fobs. The dealership will need the code inside the box and your VIN, they'll call TAC, and TAC will send out a special build of BCM flash for the dealership to install.
As I still doing my research. I have the Key system that you are able to open the door by entering the Key in the door handle if you happens to have a keyless system as you don't used a key on the door. Then you can add the remote start to the BCM with the Fobs with this # 22997089 or 91. But if you just have a regular truck lock and key with remote you won't be able to add one from this packages. You would need the BCM to be put in your truck as replace the old regular remote key system. This BCM system doesn't have a input harness to the remote start system that connect to the wires of your start key system in the dash to the stearing wheel as with or with out the Onstar.
This is what I know so far
I realize this is an old thread, what was the outcome of this? I have a 2016 lt with remote locks but no start. Gm sold me the factory kit with good latch and I am about to go get and install it. I only have code AQQ but the parts guy said it should w ork.
I installed remote start on my truck, I believe that as long a you have remote locks already the remote start kit will work. Be aware though you will have to have the bcm and fobs programmed by the dealership.
Sent from my LGLS991 using Tapatalk
Just got back from having the dealer program the remote start and all is working as it should!! Truck is a 2016 2500HD LT for anyone looking into this down the road. The code on the glovebox is AQQ and only required the new hood latch and fobs plus the programming.
Now to see if they can program a factory back up camera.
Quick question. I just installed the hood latch kit for my 2017 Silverado. Just curious after you insert the new hood latch what gets plugged into the old 3 prong connector that was for the original hood latch. I have a code now out of computer. Is this fixed in the computer when the FOBS are programed or do I need to do something else? Thank you...
Reinstall original latch. Latch and wiring is for "14 - "16 only. Same wire functions different wire locations in the connector.
Thank you. So put original latch back on reconnect and remove green wire  and newer harness that came with latch kit? and put original wire back in  where it was pin 24.and then just take for programming at the dealer?
Thanks so much for your help....
On 6/21/2014 at 1:31 PM, newdude said:
Newdude that was awesome. Is there anyway you can re-upload the pictures since theyre not showing anymore. Im having trouble woth my factory remote start. Ive followed all the wiring that leads to rhe x150 harness.
Edited by Autismtxdad
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
